1st gear Problem - Subaru WRX Forum
post #1 of 9 Old 03-26-2011, 12:27 AM Thread Starter
1st gear Problem
Hi, i'm new to this forum and have recently run into my first problem with my subie. When i'm in first gear and 1st gear only there is a ticking sound seems to be somehting in the drivetrain. The sound is simlar to that f a plastic fan hitting something. The car doesnt slip in first and when i get to second there is no sound at all. Any ideas? I'm hoping its not the tranny
Thanks- Oliver
oct6454 is offline
post #2 of 9 Old 03-26-2011, 07:08 AM
AllExtinct's Avatar
Does it make sounds when you push in the clutch?
Do you beat on the car?
Might be tranny if you dump the clutch alot.
I would take it easy on her till you can get it checked out man.
Cobb Accessport Stage 2.
JDM ej205 swap.
Home state: PA Crew
Chuck.
AllExtinct is offline
post #3 of 9 Old 03-26-2011, 01:40 PM Thread Starter
No,it doesnt make the sound when the clutch is in. No, i'm afraid something happened when i was teaching my younger brother to drive. Yeah im going to bring it in to a local shop sometime this week.
oct6454 is offline
post #4 of 9 Old 03-27-2011, 12:07 PM Thread Starter
So how much does a new tranny go for? i'm not looking to put in a new tranny but possibly just new gears.
oct6454 is offline
post #5 of 9 Old 03-28-2011, 05:59 AM
You can find a "new/used" 5 speed on nasioc.com for ~700.00. New gears will eat you alive. Unless you get a newer 5 speed from the newer generation wrx's (will it fit)?
Why not drain the gearbox and refill and see if it gets better before dumping 400.00 to a shop ?
post #6 of 9 Old 03-28-2011, 11:22 AM
baumgartenb's Avatar
and while your changing the fluid check out the drain plug and the old fluid to see if there are is any shavings or chunks in it...
Brian
2002 stage 2 WRX - DD
1993 Trans Am - summer car
baumgartenb is offline
post #7 of 9 Old 04-03-2011, 07:05 PM Thread Starter
I drained it and found shavings. I than took it to a shop and i broke a tooth off of first gear. Oh well looks like its time to get a new clutch and tranny
oct6454 is offline
post #8 of 9 Old 04-03-2011, 10:09 PM
Hondafan's Avatar
Yeah, it'll fit. Pretty sure gears are cheaper still.
-Brad
Hondafan is offline
post #9 of 9 Old 04-04-2011, 05:34 AM
First gear on your cars run about 300.00-500.00 I "believe". My bill was 2200.00 when I stripped my 07wrx 1st gear and a new clutch with labor.
