1st Cat - Subaru WRX Forum
post #1 of 7 Old 09-01-2004, 04:58 PM Thread Starter
Turbo_WRX is an unknown
1st Cat
I just had autozone run my CEL, it said it's my first catalytic converter. that's the up pipe right? does that mean the cat is aboot to go through my turbo soon? Or is it because i replaced the downpipe with a catless downpipe? holla back again and thanks.
Turbo_WRX is offline
post #2 of 7 Old 09-01-2004, 05:49 PM
Ian
Ian's Avatar
Ian is more helpful than not
Send a message via AIM to Ian
Yes it is because of the down pipe, your two o2 sensors or getting funky readings. If you get your cumputer tunned the cel will go away, I think Perrin makes a cel delete kit too, thats not to expensive. Other wise you have to live with the cel
Ian is offline
post #3 of 7 Old 09-01-2004, 07:51 PM
IBAUCLAPlaya's Avatar
Its probably because of your rear O2 sensor. You have an 02 so you can do a Pony Express MIL fix.
IBAUCLAPlaya is offline
post #4 of 7 Old 09-02-2004, 12:13 AM Thread Starter
yeah i found that cel delete wire from subydude, so i bought that. hopefully i can install it, i suck at small wires....
post #5 of 7 Old 09-03-2004, 03:06 AM
Solice's Avatar
Solice is an unknown
Send a message via AIM to Solice Send a message via Yahoo to Solice
So, when I get my TurboXS TBE my CEL is going to come on because I'll be missing 1 of 3 cat's?
Solice is offline
post #6 of 7 Old 09-03-2004, 10:57 AM
No that is not going to happen for sure. I've had my TXS turboback for a few thousand miles now and I have thrown one at around 7000 miles, a P0139, I reset the ECU and haven't had it for the rest of the time (now at 9600). All it takes for the CEL to go off, is one gust of "dirty" air. If you do get a CEL problem, just do the mechanical fix and be done with it. Its pretty easy from what I hear.
post #7 of 7 Old 09-25-2004, 05:06 PM Thread Starter
do you think "dirty air" would cause my car not to run when i'm driving sometime? like loose power?
