12' WRX. Boost Leak? Turbo Bearings? #7 Bolt? HELP!! - Subaru WRX Forum
post #1 of 7 Old 06-15-2012, 09:00 PM Thread Starter
zaklowery is an unknown
I have a bone stock 2012 WRX. 12k miles. No issues to date. The problem i'm experiencing is a whistling sound when my turbo kicks up around 3500 to 4000 RPM. Its a pretty noticeable sound. 2 thoughts come to mind. Leaking air (boost leak) or bad turbo bearing? My oil level is perfect and i've changed it ever 4k.
Here is the interesting part that might be a MAJOR clue. When I changed the oil at 4k, there was a bolt sitting in my plastic under guard. It is a bolt with a #7 on it. Similar to those which I can see on intake parts and other plastic parts under the hood. I am guessing the 7 refers to a torque spec? Is there a complete listing of where #7 bolts appear? It looks to be a 30mm long M8.
What im hoping happened is that the bolt being out finally cause the high pressure air to leak thru.... but I was hoping someone has information on the locations of these bolts so it can be the first attempt at resolving the issue.
THANKS!
zaklowery is offline
post #2 of 7 Old 06-15-2012, 10:29 PM
You under warranty?
post #3 of 7 Old 06-16-2012, 09:54 AM
Deans_socash's Avatar
Deans_socash is an unknown
If its bone stock it has to be under warranty
Aspired newb Subaru enthusiast
Deans_socash is offline
post #4 of 7 Old 06-16-2012, 10:47 AM
#7 is the grade of the bolt. Nothing to do with TQ
Take it into the dealer to have them look. That would freak me out... hahaha
post #5 of 7 Old 06-18-2012, 05:45 AM Thread Starter
Hopefully taking it in today. I'll update with any news. Thanks.
post #6 of 7 Old 07-30-2012, 02:28 PM Thread Starter
Took it in... Service managers says waste gate. Why did the waste gate make 0 noise the first 12k miles? Still driving it. I'm gonna find a local guru to diagnose; then taking it to another dealer. I wish I had the time to sort this out :-/
post #7 of 7 Old 07-30-2012, 08:23 PM
StealthTL is more helpful than not
Turbo to downpipe bolt?
That would squeal thru the gasket under power....
StealthTL is offline
