-   -   12' WRX. Boost Leak? Turbo Bearings? #7 Bolt? HELP!! (http://www.wrxtuners.com/forums/f72/12-wrx-boost-leak-turbo-bearings-7-bolt-help-32629/)
zaklowery 06-15-2012 10:00 PM
I have a bone stock 2012 WRX. 12k miles. No issues to date. The problem i'm experiencing is a whistling sound when my turbo kicks up around 3500 to 4000 RPM. Its a pretty noticeable sound. 2 thoughts come to mind. Leaking air (boost leak) or bad turbo bearing? My oil level is perfect and i've changed it ever 4k.
Here is the interesting part that might be a MAJOR clue. When I changed the oil at 4k, there was a bolt sitting in my plastic under guard. It is a bolt with a #7 on it. Similar to those which I can see on intake parts and other plastic parts under the hood. I am guessing the 7 refers to a torque spec? Is there a complete listing of where #7 bolts appear? It looks to be a 30mm long M8.
What im hoping happened is that the bolt being out finally cause the high pressure air to leak thru.... but I was hoping someone has information on the locations of these bolts so it can be the first attempt at resolving the issue.
THANKS!
pzr2874 06-15-2012 11:29 PM
You under warranty?
Deans_socash 06-16-2012 10:54 AM
If its bone stock it has to be under warranty
Aspired newb Subaru enthusiast
pzr2874 06-16-2012 11:47 AM
#7 is the grade of the bolt. Nothing to do with TQ
Take it into the dealer to have them look. That would freak me out... hahaha
zaklowery 06-18-2012 06:45 AM
Hopefully taking it in today. I'll update with any news. Thanks.
zaklowery 07-30-2012 03:28 PM
Took it in... Service managers says waste gate. Why did the waste gate make 0 noise the first 12k miles? Still driving it. I'm gonna find a local guru to diagnose; then taking it to another dealer. I wish I had the time to sort this out :-/
StealthTL 07-30-2012 09:23 PM
Turbo to downpipe bolt?
That would squeal thru the gasket under power....
