09 Stage 2- low RPM almost stall - Subaru WRX Forum
post #1 of 12 Old 05-06-2011, 02:19 AM Thread Starter
bizzle's Avatar
bizzle is more helpful than not
Send a message via Yahoo to bizzle
Howdy folks-
I did do a search- closest problem was someone with an 08 having a stutter problem above 2k RPM- which is not the issue I am having.
Seems every time I put in the clutch from taking the motor over 3k the rpms drop like a stone and the car almost dies. Before, if I was still in first and putting in the clutch in the parking lot, the rpms would rise to a bit over 2k, but now it won't even do that. This evening the rpms went so low the motor started making a knocking noise before the idle brought it back up to the normal rpm idle range.
Mods:
Cobb catted DP
SPt cat back
Cobb Stage 2 91 ACN OTS map
Chevron 91 Octane fuel
Issue popped up about 2 weeks ago after my 30k servicing. Used to only happen once in a great while- now its every time I put in the clutch. Temps here in Vegas have also been climbing- hitting mid 90s now in the day. I have no CELs, no check engine light, and my intake is completely stock.
I would hook my AP back in and monitor, but every time I do that now my AP says there is a ECU bus communication error and does not allow live monitoring. I can still flash maps, but as soon as the motor is running, I cannot do anything with the AP.
Any ideas on where to start would be much appreciated. I fear my only choice is probably getting a pro-tune, which will require me to go open source because no one local can tune AP.
Thanks in advance!
-Dustin
bizzle is offline
post #2 of 12 Old 05-06-2011, 06:37 AM
So you don't have an aftermarket drop in filter ? No BPV other than stock ?
post #3 of 12 Old 05-06-2011, 09:15 AM Thread Starter
bizzle's Avatar
Nope- intake completely stock.
Just replaced the OEM air filter with another from the dealership in fact.
Never touched anything else- I do have a Perrin TMIC, but it has not been installed yet.
The stock IC has been taken off a few times- including by the dealer this last time because I thought I had a small oil leak at the oil sending unit- something noticed by the guy that helped me with my DP. Dealership checked it out and said I was smoking crack- no leaks.
bizzle is offline
post #4 of 12 Old 05-06-2011, 09:25 AM
Try cleaning your MAF and reset the ECU.
Just read the part about the communication error. Do you have the last firmware update on your AP ? It wouldn't suprise me that the dealer reflashed the car to mess with you.
post #5 of 12 Old 05-06-2011, 10:27 PM
Is your A/C on? My car used to die after my one tune with the A/C on. I took it back to my tuner and there is a option in the AP to make the idle higher with the A/C on. He set that higher and it completely solved my problem.
Edit: That was done with the engine running...I'm pretty sure. I'd try to update your firmware and see if it lets you change that setting.
post #6 of 12 Old 05-07-2011, 02:53 AM Thread Starter
bizzle's Avatar
This is not with my A/C on- I rarely run that- and usually once the temps reach around 115-120 do I finally start using it.
Looks like it won't be long now before I get to those temps since today was over 100 already.
One other issue I have been told about- but not sure if it matters- twice now an oil change place has checked my battery and told me it was getting low and should consider changing it. I take it to the dealership since I am under warranty, and they tell me it is fine since it still starts the car.
Sometimes when I am just sitting at idle and go to roll two windows- or even sometimes one- the idle will dip and almost die then as well. Doesn't always do it- but it has become pretty noticeable and regular.
As for the AP, I'm not sure on the firmware. I bought off Boost_Addict's store a year ago now. I will have to bring it in and check it out- and also check to make sure I am still running the Stage 2 ACN map for 91 octane.
bizzle is offline
post #7 of 12 Old 05-07-2011, 04:47 PM
Whats up with everyones batteries as of late? Subie trying to cut costs on batteries?
Even if the AP was new in the box, it might still need a firmware update (shelf life).
post #8 of 12 Old 05-08-2011, 01:44 AM Thread Starter
bizzle's Avatar
Looks like my firmware is version 1.5.0.2-11526.
So now I am looking at updating the firmware, but all my computers run 64 bit windows 7- which Cobb's software doesn't support- go figure.
Will be messing with a virtual machine setup tomorrow then- had to do the same thing to register my Garmin- what a pain.
-D
EDIT: So I used a computer I just built for my mother for Mother's Day- runs 32 bit Win 7. Have the AP updated, now I will reflash the new V300 Stage 2 map tomorrow- and see if the AP will still talk to the ECU while the engine is running. I'm still thinking the battery is a bit of an issue- even if the dealer says its good to go. I know the car sat for a bit when I first ordered it- and then it only had light driving while I was finishing up my last six months in Iraq. During that time the battery did completely die once- so who knows. For a replacement I really like the optimas- but seems the new trend out here in the desert are those real light weight half batteries.....
bizzle is offline
post #9 of 12 Old 05-08-2011, 05:30 PM
shaggy's Avatar
shaggy is an unknown
my battery didn't even make it 2 years
SHAGGY
14 STi Hatch
shaggy is offline
post #10 of 12 Old 05-08-2011, 08:50 PM
Get an interstate and call it a day... Optima is overated
post #11 of 12 Old 05-08-2011, 11:20 PM Thread Starter
bizzle's Avatar
Okies-
So- did the whole re-flash thing and so far, the stutter has diminished- quite a bit. But since I did a reflash, the ECU seems to have gone back into a re-learn phase since I get a little throttle hesitation and not as responsive engine power. I remember it doing this when I first flashed Stage 2, so I will have to wait it out awhile to see if it made a long term difference.
Good news is the AP is talking to the ECU now when the motor is running- so thats a plus. Will have to keep an eye on it and see how long it lasts- hopefully it won't start the whole communication error thing again. Got in touch with a reputable tuner- going to see if he does AP tunes or not. If not, I will probably make the switch to open source and sell the AP- should cover the costs of tune plus cable.
Thanks guys- will let you know what happens....
-D
bizzle is offline
post #12 of 12 Old 05-09-2011, 06:37 AM
Glad it worked out. AP's are like the wiminz. !Laugh!
