08 wrx brake light flicker - Subaru WRX Forum
post #1 of 5 Old 02-11-2010, 04:29 PM Thread Starter
Wutangjn12's Avatar
i have a 08 wrx sedan, and ive noticed that my e brake light keeps flicker under heavy accelearation. any idea what it could be. my rotors are warped and the pads are probably pretty low
Wutangjn12 is offline
post #2 of 5 Old 02-11-2010, 05:33 PM
The easy answer is. Are they so warped that it might be rattling the e-brake mechanism on the rear brakes? I mean, that just seems too simple though. If they're not that warped. Something else is causing it.
post #3 of 5 Old 02-11-2010, 09:47 PM
the pads are low causing the fluid in the master cylinder to be low as well causing the low fluid sensor to trip when you speed up fix your brakes get new pads and rotors you will be fine....
WTRacing is offline
post #4 of 5 Old 02-11-2010, 10:59 PM Thread Starter
Wutangjn12's Avatar
word thanks broski
post #5 of 5 Old 02-11-2010, 11:08 PM
anytime
WTRacing is offline
