06 wrx making weird noise - Page 3 - Subaru WRX Forum
post #31 of 38 Old 09-19-2011, 08:37 PM
That was my next assumption if it didn't sound like my video.
post #32 of 38 Old 09-19-2011, 08:38 PM
You and I agree upon alot of things. So it's safe to figure that it's a boost leak...hehe
post #33 of 38 Old 09-20-2011, 01:10 AM
ukwrx is an unknown
No it does n't sound like that second video. Its more regular hence the ticking comparison.
If its a boost leak how do I go about finding it?, given that it only does it when under load. Under the hood there are no unusual noises.
ukwrx is offline
post #34 of 38 Old 09-20-2011, 04:04 AM
Boost Leak tester. This is a DIY project so you get to have some fun...
How To: DIY...another boost leak tester - Subaru Impreza WRX STI Forums: IWSTI.com
post #35 of 38 Old 09-20-2011, 10:52 AM
Glad that we narrowed it down for you....Just need to find the boost leak now
post #36 of 38 Old 09-20-2011, 01:42 PM
ukwrx is an unknown
thanks for the help guys. I'll look into the boost leak tests. I did some monitoring with an obd2 digital gauge today looking at the Manifold absolute pressure, this is 14.6 before starting (atmospheric) The ticking seems to occur below this figure from 6-13psi. although I think the gauge is a little slow to update and my gut feel is that its really happening between 10-13 psi. Logic would tell me this is around low vacuum conditions. Does this mean its more likely a vacuum leak, or is that the same as a boost leak? Is the noise a valve clicking or the air escaping? What do you think?
ukwrx is offline
post #37 of 38 Old 09-20-2011, 02:06 PM
Normally if you have a vacuum leak you will notice bad idle issues and low vacuum reading. The car should pull 17-19in/hg of vacuum. Not sure how that would translate for you, but I'm sure there is a conversation chart on the web. The noise should sound like air escaping...
post #38 of 38 Old 09-20-2011, 02:34 PM
Also the brakes run off the vacuum system and the brakes should barely work if the vacuum is that far off.
