06 Clutch...Bad? - Subaru WRX Forum
post #1 of 2 Old 08-07-2006, 05:01 PM Thread Starter
WRXbkaus's Avatar
WRXbkaus is an unknown
06 Clutch...Bad?
I experienced my first problem with my 06 yesterday.
I had just left the xgames and flipped a U-turn, and I smelled my clutch burning.
Stopped at the light with it in neutral. And when I was ready to go, I was locked out of all of my gears (1-5, and R).
I had thought my clutch was fried. It is my daily driver, I am not very hard on it. Right now only 12K miles.
Took to subaru,.... Monday they said everything was working properly and that there was no problems.
Now I have to drive it untill my clutch breaks again.
WRXbkaus is offline
post #2 of 2 Old 08-07-2006, 07:30 PM
More then likely you did the same thing I did at the Drags this weekend.. If you managed to over heat the clutch disk it will cause the situation you are describing.. I grabbed 2nd gear and my clutch slipped through 2nd and then I had to wait for 30 minutes after wards before it cooled enough that I could get into reverse..
