05 wrx coolant leak... - Subaru WRX Forum
post #1 of 2 Old 04-08-2010, 08:45 PM Thread Starter
hoookie is an unknown
I have a 2005 wrx, and for the past couple days, i've been spraying a lot of coolant. It appears to be coming from the passenger side, at the top, and is spraying hard enough that it's spraying the boost controller. I can't see any definitive place that it's coming from, but it appears to be coming from maybe where the plastic tank is attatched. Any ideas?
hoookie is offline
post #2 of 2 Old 04-09-2010, 10:12 AM
You cant tell where it is coming from? Take the 2 bolts out of the tank and lift it up a little then maybe you can tell where it coming from. If that dosent work then take it to a shop and have it pressure tested.
nagyhead is offline
