03 WRX chugging/jerking on hard acceleration - Subaru WRX Forum
post #1 of 15 Old 11-19-2011, 04:37 PM Thread Starter
tsikows is an unknown
just picked up an 03 wrx a week ago. runs great drives great. only mod is k&n typhoon intake.
my problem is that when i put it to the floor i will get a chugging or jerking that shakes the whole car as my rpms climb. it lasts from about 3 grand up until i shift, then it will stop. happens in third gear if that means anything. what could be causeing this?
possible relivant info.
this happened about three or four times now since i got the car. on the third time about 30 seconds after my CEL light flashed for a bit while coasting down a hill. the next day it did it again on my way to work. this time it set a code and CEL stayed on. scanned it once i got to work and it came up as a cylinder 1 mis.
I swapped coils on one and three for now so that if the light comes back on it tell me if a coil is causing the mis. in the mean time what could be causeing the chugging?
tsikows is offline
post #2 of 15 Old 11-19-2011, 06:10 PM
Put the factory air intake back on.
post #3 of 15 Old 11-19-2011, 06:15 PM
^Agree 100%
you might also want to give the plugs a quick check if it still does with the stock intake on
post #4 of 15 Old 11-20-2011, 12:41 AM Thread Starter
i dont have the stock intake to put on it
tsikows is offline
post #5 of 15 Old 11-20-2011, 02:45 AM
ejs0806 is more helpful than not
put it on craigslist trade for stock intake plus a little money on there end... Intakes dont do much for our cars anyway from what everyone says on here they do more harm then good
ejs0806 is offline
post #6 of 15 Old 11-20-2011, 06:24 AM
They can add power, but unless you know what your doing I wouldn't do it. Plus it's really not worth it in my opinion on the older models unless you are making a good amount of power.
post #7 of 15 Old 11-20-2011, 07:27 AM
AllExtinct's Avatar
Had same problem with my K&N Typhoon. Put stock box back on w K&N drop-in and no more problems. I was getting misfires also. I wouldnt go messing with your coil packs just yet, check your simple solution first.
Check E-bay for stock box if you dont have yours.
Good luck man.
Cobb Accessport Stage 2.
JDM ej205 swap.
Home state: PA Crew
Chuck.
AllExtinct is offline
post #8 of 15 Old 11-20-2011, 08:34 AM Thread Starter
thanks for all the help guys. ill see what i can find
tsikows is offline
post #9 of 15 Old 11-20-2011, 10:11 AM
The 2 post above you is something you don't see everyday. 2 Sedona Red Pearl WRX's together....
post #10 of 15 Old 11-20-2011, 05:41 PM
Actually 3 I have one too just no pics good enough yet to show lol
ejs0806 is offline
post #11 of 15 Old 11-20-2011, 06:40 PM
Take some then....hurry this may not last long...lol
post #12 of 15 Old 11-21-2011, 07:05 PM
AllExtinct's Avatar
Sedona!
JDM ej205 swap.
Home state: PA Crew
Chuck.
post #13 of 15 Old 11-22-2011, 05:41 AM
Hey,
My buddy has the stock intake box and snorkle for sale.
If you are interested, let me know.
post #14 of 15 Old 11-22-2011, 08:00 AM Thread Starter
all good to go. did plugs and a bad coil. everything is good to go. problem solved
tsikows is offline
post #15 of 15 Old 11-22-2011, 12:06 PM
cwinterbower is more helpful than not
Just hope your maf is tuned for your K&N, or plugs and a coil will be the least of your concerns =).
cwinterbower is offline
