03 wrx cel on for awhile - Page 3 - Subaru WRX Forum
post #31 of 46 Old 06-05-2009, 09:30 PM
pb-king07's Avatar
+ 1 V24 If you don't want the help then don't ask. Im sure your BOV is messing with the cars air/fuel really bad. I had a BOV on my car for 2 miles the car ran like crap. ya the BOV sounded cool but it is not worth having it on there. if you have the money for a WRX/STI then don't go cheap on parts. you did not buy a cheap car so why buy cheap parts. but thats just IMO. its your car and your money
pb-king07 is offline
post #32 of 46 Old 06-05-2009, 09:58 PM Thread Starter
i bought the car used , exhaust , intake bov etc already on . i do want help , just didnt feel it would be necessary i see wrx / sti all the time with the same shit running fine .
03wrx84 is offline
post #33 of 46 Old 06-06-2009, 03:10 AM
03 CrazyTaxi's Avatar
Not all intakes are created the same. Statement works for the BOVs as well. Because the WRX and STi are MAF cars, they tend not to like BOVs. Unless you go through the trouble of relocating the MAF to the throttle body, I'd recommend removing the BOV in favor of the stock BPV or a 50/50 type. As for the intake, they tend to mess with the MAF voltage readings. This is something that a tune would take care of.
03 CrazyTaxi is offline
post #34 of 46 Old 06-06-2009, 08:04 AM Thread Starter
ok thanks
03wrx84 is offline
post #35 of 46 Old 06-14-2009, 04:19 PM Thread Starter
okay thanks for your help . PROBLEM FIXED . the cel was b/c there was a small crack in the line running to the waste gate . the reason it was running rough was my MAF sensor got wet . took the car to subaru paid a little , but after this long i didnt mind . car is running better than ever .
now i have a wheel hub bearing in the rear that sounds nasty . do these go often ?
also my car has around 70k and my spark plugs have not yet been changed , what does subaru charge for this ? thankyou all
03wrx84 is offline
post #36 of 46 Old 06-14-2009, 09:00 PM
Yes Subaru will charge for this but you can do it yourself for MUCH cheaper.
You'll need a 10mm, 12mm, and 5/8" spark plug sockets, various length extentions, a 10mm box wrench, a spark plug gap tool and a flat head screwdriver. Pull the battery, washer fluid tank (just put it on the shock tower without unhooking the fluid line), and the air filter housing. Work on ONE plug at a time. Pull the coil pack off using a 12mm socket. Using the spark plug socket and a short extension, pull the old plug. Gap the new plug to .028 and install the new plug. Be careful you don't cross thread it or you'll have to pull the motor and helicoil everything... Put the coil pack back on and tighten it down. Repeat on all cylinders, reinstall the filter housing, washer fluid tank, and battery.
post #37 of 46 Old 06-16-2009, 06:36 PM Thread Starter
thanks crazytaxi , most helpful . what about the wheel bearings ?
03wrx84 is offline
post #38 of 46 Old 06-16-2009, 08:43 PM
Unless you have a hydraulic press, you'll have to take that into a shop. I replaced mine at around 106k miles.
post #39 of 46 Old 08-16-2009, 04:49 PM
yelljack's Avatar
I am getting the same code. I'll list all the facts. Parts list: TBE (catless, shh don't tell the state), walbro 255 lph, xs power tmic, 11.5lb flywheel, exedy street disc clutch, K&N typhoon CAI, GFB hybrid BOV set to 50/50, Cobb AP Stage 2 maps. Now I know everybody's first thoughts are, get rid of the CAI and get a custom/ pro tune. However, I've been running this setup for over a year, the CAI even longer (used a unichip b4 the cobb), without any problems. One day for shits and giggles I decided to reconfigure the typhoon as a SRI, boom P0171. Here is the list of things I have done to trouble shoot, some of them didn't make sense to me but I took peoples advice and did it anyways:
changed the oil
cleaned the MAF
changed the fuel filter (engine compartment one)
tried to clean the oil feeder line filter, car didn't have one ( pulled the bolt out of the line..no filter)
cleaned my k&n filter
went back to stock intake with the k&n drop in
........................ so there it is and remember, I was running that setup for a long time, problem free.
next thing I'll do is the carb spray and if I have to, the in tank fuel filter.
So, any Ideas???
forgot, blitz dual turbo timer
and, after everything I've done to trouble shoot I reset the ECU via the AP
also, I have been using the AP to monitor A/F ratio, it stays in the 14s under acceleration and the CEL only seems to come on when I am not accelerating. if I am driving it like I stole it the light doesn't come on, it is when I am cruising at a constant speed, yjay is when it always comes on.
yelljack is offline
post #40 of 46 Old 08-16-2009, 05:28 PM
P0171 CEL Thread - Everything you ever wanted to know? - NASIOC
Read the "first disclaimer" on the link.
It happened because you reconfigured the typhoon CAI to a SRI. Either change it back to how it was or get a professional tune.
P0171= Fuel trim malfunction (A/F too lean)
post #41 of 46 Old 08-16-2009, 10:48 PM
Exactly the problem. Any intake change can mess with the MAF causing either a lean or rich code.
post #42 of 46 Old 08-18-2009, 01:33 PM
yelljack's Avatar
As stated above I have done all that. The carb spray rendered no results. And, changed the front O2. I am just getting ready to say f%^k it and deal with the light.... the Cobb AP says I'm not actually running lean, and I go back to Iraq in a month. I plan on upgrading the turbo upon return in which case I'll buy the intakes reccomended by Cobb.
yelljack is offline
post #43 of 46 Old 08-18-2009, 02:06 PM
Did you reconfigure it back to CAI? If so a simple custom tune is cure to all.
Good luck in iraq.
post #44 of 46 Old 08-18-2009, 07:22 PM
20 bucks says Cobb recommends Cobb's intake
post #45 of 46 Old 08-19-2009, 01:19 PM
Cobbs stage one and two notes say stock intake or panel filter last I looked at them.
