03 wrx cel on for awhile - Page 2 - Subaru WRX Forum
post #16 of 46 Old 05-25-2009, 06:41 PM Thread Starter
03wrx84 is an unknown
i looked under the hood today and everything {as far as i can tell} seems to be hooked up .
03wrx84 is offline
post #17 of 46 Old 05-25-2009, 06:56 PM
VD5505's Avatar
do you have the stock boost controller on your car? sounds like your just running wastegate only. Try starting your car and getting a can of carb and choke and spray the carb and choke around some of the vacuum lines and see if it affects the idle at all.
VD5505 is offline
post #18 of 46 Old 05-26-2009, 06:00 PM
03 CrazyTaxi's Avatar
+1 to the carb/choke cleaner
For the boost, check the lines between the turbo, wastegate, and boost control solenoid. Between the turbo and the T that leads to the wastegate there should be a slight bulge where a restrictor pill would be. Should be a hard spot since it's a small brass bead. The BCS is located between the strut tower and the air box under that black cover. If you can, take a close up picture of the lines and the solenoid and post it. May help in determining what a previous owner may have done to the car.
03 CrazyTaxi is offline
post #19 of 46 Old 05-31-2009, 05:23 PM Thread Starter
tried the carb cleaner on vac lines and ................ nothin !! . good suggestion though . so anyway , what now ?
03wrx84 is offline
post #20 of 46 Old 05-31-2009, 05:24 PM Thread Starter
taxi i will try to get a pic up , may take time . thanks
03wrx84 is offline
post #21 of 46 Old 06-03-2009, 06:29 PM Thread Starter
ok so i had a o2 sensor put in and then the ecu reset. im on my way home from work and i get on the highway . i was only pushing 8 lbs of boost before and now the needle will climb to 20 lbs no problem{effortlessley compared to before } so uh ........... yeah it shot up to 20 and then kind of cut out and bang the cel popped on . help............... any thoughts ? ? ? ? thank u all
03wrx84 is offline
post #22 of 46 Old 06-03-2009, 07:05 PM
is it the same CEL?
I think it's really important that you let us know if your BOV is 50/50 hybrid or fully atmospheric. If you dont know, you should post a pic. Try to find a stock one and put that on their, and put the stock intake back on. It has to be your CAI causing all those issues for you.
That or get a downpipe and a tune.
post #23 of 46 Old 06-05-2009, 12:35 AM
You hit overboost and the car freaks out. It goes into fuel cut and kicks on the CEL. You need a tune, check that the BCS is working properly, and/or check the boost lines between the BCS, turbo, and wastegate.
post #24 of 46 Old 06-05-2009, 01:11 AM Thread Starter
baller- id rather not remove my intake and or bov , although this was a previous suggestion . {infact by subaru.}
crazytaxi - i think a tune up is what i will do next . i dont know any1 who works on these cars that envolved . so i was going to take it to subaru . any idea how much a tune up should from through them ? also , and these questions are for every1 to help answer, what are the chances even if it is just opinion that the cel is the same ?
thanks big help guys
03wrx84 is offline
post #25 of 46 Old 06-05-2009, 01:12 AM Thread Starter
thats any idea a tune should run through them , sorry its late !!
03wrx84 is offline
post #26 of 46 Old 06-05-2009, 01:16 AM
pb-king07's Avatar
pb-king07 is an unknown
You don't need a tune up your car needs a pro tune. and do you have the stock BPV. Not a BOV???
pb-king07 is offline
post #27 of 46 Old 06-05-2009, 09:29 AM Thread Starter
no i dont have the stock parts
03wrx84 is offline
post #28 of 46 Old 06-05-2009, 09:30 AM Thread Starter
how much might a pro tune run thanks
03wrx84 is offline
post #29 of 46 Old 06-05-2009, 09:50 AM
Cheapest route for a tune is to find someone that has a Tactrix cable and EcuFlash, I can send you a stage 2 tune for your 03 via e-mail. Just flash the tune onto the car with the tactrix and you should be good. Ask on your local forums about it. Another engine management route is the Cobb AccessPort. Personally, I have very little experience with them but I've heard great things about them from the local guys/gals. That's the more expensive route. An AP will run around $400 used and then the tune will run another $100+ unless you use the OTS maps from Cobb which are extremely "safe" tunes.
As for the CEL, if it felt like the car just fell on its face HARD and then the CEL kicked on... It's not the same one.
post #30 of 46 Old 06-05-2009, 11:29 AM
So the fact that subaru and all of us are recommending to remove your CAI and/or BOV is not worth a try? We are trying to help you fix your problem, but it doesn't help if you won't listen to any of us.
