02wrx check engine light problem - Subaru WRX Forum
post #1 of 8 Old 08-27-2008, 02:53 AM Thread Starter
My check engine light always turns on because I have a High Flow catalytic converter on it. Does any body know a way to turn it off for a good one mechanic said he could replace a o2 sensor with a circuit so it would not read the emission error for like $186. HELP ????????
WRXTHOR is offline
post #2 of 8 Old 08-27-2008, 02:28 PM
Imprezd02's Avatar
Send a message via AIM to Imprezd02
Dont pay $186 for a cel fix, please.
Go to autozone and pick up a spark plug anti fouler
drill a 1/2" hole in the tip
Screw your 02 sensor into the anti fouler
Then screw the anti fouler into the exhaust.
No more cel
Imprezd02 is offline
post #3 of 8 Old 08-27-2008, 07:35 PM
The fault code for the catalytic converter may be caused by a Mass Airflow Sensor that is out of range. Replacing it will fix your problem.
_________________________
Autopartswarehouse Addict!
Khooper is offline
post #4 of 8 Old 08-27-2008, 09:23 PM
Let me get this straight. You decided to make this thread twice and NEITHER go in the forum they belong? LOL. Fixed btw...
-mosc
post #5 of 8 Old 08-30-2008, 02:28 PM Thread Starter
Thank you sorry I did not mean to enter twice it was some sort of glitch
WRXTHOR is offline
post #6 of 8 Old 08-30-2008, 07:18 PM
just unplug the positive side of the battery for like two min... then plug it back in and see if that works!
I did when mine would keep coming on and know its back to normal.
lyndzy71 is offline
post #7 of 8 Old 09-30-2008, 04:41 PM
Send a message via AIM to blk02wrx
do the spark plug defouler and unplugg the battery for a bit and hit the brakes a couple times. hooked the battey back up and it shouldn't come back on. and it will cost you about $4
O2 PEARL BLACK WAGON with some modds
blk02wrx is offline
post #8 of 8 Old 09-30-2008, 04:59 PM
isd_intrepid's Avatar
Send a message via Yahoo to isd_intrepid
Do It!!!!!!!!!
Do It Now!!!!!!!!!!
isd_intrepid is offline
