02 Wrx Rough Idle/ Stalling after fmic install - Subaru WRX Forum
post #1 of 10 Old 05-30-2011, 07:57 PM Thread Starter
I own a 2002 Subaru Wrx. Recently I installed a Turbo XS Fmic, and now I have a rough idle and when the idle does level out it runs smoothly for 1-4 mins before stalling out. I have hooked up to a scan tool to the car, and it shows a code that the vechile is running lean. I have a Walbro 255 fuel pump on the way. My question is, will the fuel pump be enough to resolve the issue, or will Sti pink injectors and a tune be needed to correct this problem. Other mods on the car are a apexi cat back exhaust system, Blitz turbo timer, Turbo XS boost controller, and AEM intake.
Sbru02 is offline
post #2 of 10 Old 05-30-2011, 08:09 PM
You have a vacuum leak, check all your connections.
post #3 of 10 Old 05-30-2011, 09:30 PM Thread Starter
Thanks man I did check the connections at the time of the install, but there could be a good chance I missed something. I will def go back and check them over.
Sbru02 is offline
post #4 of 10 Old 05-30-2011, 10:03 PM
Good luck
post #5 of 10 Old 05-31-2011, 12:28 AM
If the car is stumbling and stalling, it's pretty significant that you can probably spray some maf cleaner or starter fluid around the joints and it will raise the idle up once it gets sucked into the piping.
That's how I found the big leak I had which caused my idle to stumble and run 19:1 or higher lean at idle.
post #6 of 10 Old 05-31-2011, 01:13 AM
Ya, definitely a leak. That being said, that's a TERRIBLE mod for your setup. That intercooler will do more harm to you performance than anything with what you've got. Even with a larger turbo it's a bad investment (IMHO nothing 99% of people will ever do a on a stock block 2.0L will warrant a FMIC). You're running an intercooler designed for +/- 50 lb/min turbos running high boost.
post #7 of 10 Old 05-31-2011, 10:35 AM Thread Starter
Thanks for all the suggestions. I will check all the connections out tonight, with some starter fluid, and retighten any connections that may need it. Will post how it turns out.
Sbru02 is offline
post #8 of 10 Old 05-31-2011, 04:29 PM
Your not that far away from me man. But, I can't help with TurboXS boost controller set-up. I hope you figure it out.
post #9 of 10 Old 05-31-2011, 04:51 PM Thread Starter
Yeah I see your close. Its cool, I don't usually run the car with boost controller on. The guy who had it before me had it installed.
Sbru02 is offline
post #10 of 10 Old 05-31-2011, 07:34 PM Thread Starter
Well some conectors were loose. Tightened them, still ran kinda off, so messed around with my afc, n bumped the fuel up it seems to have worked, the missing is gone and no more stalling out.
Sbru02 is offline
