02 WRX problem with the turbo vacum hoses "T" - Subaru WRX Forum
post #1 of 20 Old 05-04-2010, 09:50 PM Thread Starter
alexxxphilly is an unknown
Send a message via AIM to alexxxphilly
hey guys i got a 02 wrx stock only mod is cobb intake sf.
i noticed one of the turbo vacums was leaking bottom part of the "T" so i went and got a new vacum hose and intalled it but the car feels so damn slow. i can hear the turbo spool and the the boost gauge says .8mpa in first gear. well i completly ignored that there was this "restrictor thing " and went stright but i see that 06-07 dont have a restrictor, so i wana know if thats the problem or what could it be? . sorry sounds complicated hahaha thats the only way i can explain it! i hear turbo and see boost but the car dont pull hard at all!!!!
alexxxphilly is offline
post #2 of 20 Old 05-04-2010, 10:02 PM
Where did you see that 06-07 doesn't have a restrictor pill? Because my 06 wrx tr and 06 wrx sti both had a pill. It doesn't now because I run a 3-port bcs and its not necessary at this point. I'd say re-install the pill and it'd fix your problem.
post #3 of 20 Old 05-04-2010, 10:11 PM Thread Starter
no no no... i know about the pill thats inside of the vacum hose.. thats fine. im talking about the one that the "t" stands that goes im guessin to the boost controller... it had like a restrictor made of plastic...
post #4 of 20 Old 05-04-2010, 10:15 PM Thread Starter
cant post pics but heres the link look at line 3 thats the one im talking about it goes stright from one side to the other. well mine was cut in half with some kind of restrictor made of plastic
http://forums.trinituner.com/upload/...ulletinrk2.jpg
post #5 of 20 Old 05-04-2010, 10:20 PM
Just like the picture. I've never seen a restrictor in that line. But, then again. I've only owned 06 subies.
post #6 of 20 Old 05-04-2010, 10:24 PM Thread Starter
yeah idk i gotta ask some bugeyes owners i guess.... yeah its a plastic thing just like the "t" but in a "i" same color and all... idk
post #7 of 20 Old 05-04-2010, 11:17 PM
jdowrx's Avatar
jdowrx is an unknown
I think i know what you're talking about, but i've had a 3-port for awhile so i don't remember for sure. Its basically a "coupler" in that line. I dont think its suppose to be a restrictor though, and you said you're still getting the same boost, correct?
jdowrx is offline
post #8 of 20 Old 05-04-2010, 11:25 PM
first off .8MPa is 116 PSI...
post #9 of 20 Old 05-05-2010, 09:41 AM Thread Starter
Yeah my car always had full boost at .8mpa = 11.5psi never to 1mpa.
If I disconect that hose it goes to 1mpa. I know it weird.you can hear boost spool but it's not pulling good.... Any advices?
Should I hit 1mpa in first , second, third.....? I'm stock
post #10 of 20 Old 05-05-2010, 10:39 AM
blazed2002bugeye is more helpful than not
wow this guy has a bugeye that boosts 116 psi..damn what am i doing wrong iam only boosting 16psi lol..well my man i just looked at mine..my line goes strait to the boost controller no connector..someone cut that line for some reason
what is your major malfunction numb nuts
blazed2002bugeye is offline
post #11 of 20 Old 05-05-2010, 01:29 PM Thread Starter
.1mpa
post #12 of 20 Old 05-09-2010, 09:39 PM Thread Starter
OK. So i finally found a pic of what i was talkin about! this damn spliter here is what i had! two of them! and i found out that others besides bugeyes just run a stright vacuum hose!
now if anyone can explain why , may be bugeyes owners.... without this spliters i can actualy get the normal boost, with them i get like 8psi only..... is it bad if i just leave the stright hose?
http://www.vishnutuning.com/images/install/wrx_pill.jpg
http://img7.imageshack.us/img7/5690/img7800m.jpg
post #13 of 20 Old 05-10-2010, 10:24 AM
That's retarded looking. I'd get another 2 port bcs and run the straight vacuum line. OR even better, get a 3 port bcs and a protune. Unless you're OS tuning it already and can tune the 3 port in yourself.
post #14 of 20 Old 05-10-2010, 10:46 AM Thread Starter
I know it does look so retarded! But my concern is why did they do that?! I'm 100% it's factory! I just don't get it. With all that I ran half
of the boost with a stright vacum hose I get the stock 14.5 psi... I don't understand.
post #15 of 20 Old 05-10-2010, 01:03 PM
fearthiswrx is an unknown
I have a 2002 WRX and that's how it is on mine from factory. Not sure why, but that's how it is. I did wonder if someone had changed it since i didn't get this car new. Anyways, it should not keep you from reaching more boost. you might have a leak in one of the tubes.
fearthiswrx is offline
