Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Problem Diagnosis
Old 04-01-2005, 09:49 AM   #1 (permalink)
Reputation: 02WRX is an unknown
02 WRX not start intermittently
Hello,
Over the past week or so I've expeirenced issues with my WRX starting. When I go to start the car I push in the clutch, turn the key and it doesn't even try to turn over. It's like I am trying to start the car without pushing the clutch in. I'll keep trying to start it several times and eventually it will start up perfectly, no hesitation or trouble idling.
About a week ago I would say this would happen about once every 5 starts or so, now it's happening everytime. If I turn the key into the start position and continually push the clutch in, it will eventually start which makes me believe it's something with the switch on the clutch that prevents the car from starting without the clutch being pushed in..
Has anyone else had this problem? I don't think it's a battery problem because when it does try to start, it starts up without a problems.
It's completely stock I haven't had any problems with it up to this point.
I really apprecaite any advice or input.
Thanks,
Jason
Old 04-01-2005, 10:44 AM   #2 (permalink)
Cosmo's Avatar
Images: 15
Reputation: Cosmo is known to be trustworthy and helpful Cosmo is known to be trustworthy and helpful
There is a switch that detects when the clutch is depressed, and that allows the key to activate the starter. That could be the cluprit.
Old 04-01-2005, 11:04 AM   #3 (permalink)
Do you know where abouts the switch is at? Is it something I can access by looking under the dash or do I have to start taking dash components out to get to it?
Old 04-19-2005, 02:06 PM   #4 (permalink)
I think the connection on the switch was loose or something because I tightened it and I haven't had the problem since.
Thanks for your help,
Jason
Old 04-19-2005, 10:50 PM   #5 (permalink)
Car: 04 WRX
A bad battery is a possibility too.
EDIT: sorry, posted before I read the whole thing
RIP Colin McRae
