02 wrx (CEL) - Subaru WRX Forum
post #1 of 13 Old 06-09-2010, 07:26 PM Thread Starter
Dougie is an unknown
02 wrx (CEL)
It is a 02 wrx, with a full Cobb exhaust and Cobb stage II chip. I need to pass inspection so i reprogrammed the ECM back to stock. So really were only working with a full turbo back Cobb exhaust. Im getting a P0420, and i have read that its a rear sensor code, but i also dont have a cat. So will replacing that sensor do anything or dose anyone know if i can use like a spark plug fowler to pull the sensor away from the exhaust stream, a resister i can put inline or anything? I just need to pass inspection.
Dougie is offline
post #2 of 13 Old 06-10-2010, 12:07 AM
the easiest way would to just get an opensource stage 2 tune with that particular code disabled
post #3 of 13 Old 06-10-2010, 09:28 AM
fuapiti's Avatar
I tried all tricks to cheat the O2 sensor code thing when I first installed the DP/UP. None of them worked, the only thing that worked was to reprogram...
I got a question though: How would it be possible to pass inspection with no cats? I did not have that problem while in FL but now in PR I do have to pass inspection... which I do, with a few extra bucks, if you know what I mean... ...just wondering
fuapiti is offline
post #4 of 13 Old 06-10-2010, 11:03 AM
some states inspection just check to make sure there are no emmission DTC's but then others like NY, CT, CA, MD and others but the sniffer in your tailpipe
which is why as soon as I started college in FL I got FL plates before I even checked into the dorms for the first time
post #5 of 13 Old 06-13-2010, 01:37 PM Thread Starter
Fuapiti - There suppose to visually inspect for cats but i know a couple inspectors who will let that slide, however in NC any car 96^ has to bee hooked through your OBDII connector and it connects directly through the state computer so you cant drop and extra 80 buck on the table like you could a couple years ago
Now with that said, I have a tuner chip that disables the light but i believe it also disables communication. So can anyone list some of the cheats I can maybe try?
Dougie is offline
post #6 of 13 Old 06-13-2010, 03:34 PM
like I said before if you get a new tune with the CEL disabled you will be fine
post #7 of 13 Old 06-13-2010, 05:28 PM
The Cobb stage 2 took care of disabling that. Have no idea why you flashed back to stock when the Cobb stage 2 map will easilly pass emissions............
dumdum is offline
post #8 of 13 Old 06-14-2010, 01:38 PM Thread Starter
Well this is my cousins car, he said when he took it to get inspected they couldnt connect to his ecm at all and was told that it was because his tune chip. So i told him to re-flash it back to stage II and take it to a different place. So ill let ya'll know what happens after he dose this.
Dougie is offline
post #9 of 13 Old 06-14-2010, 09:10 PM
03stg2wrx's Avatar
03stg2wrx is an unknown
the way I passed inspection was that I got a fake cat welded in my downpipe and I parked close to where I was getting the car inspected and unhooked the negative on the battery for like ten minutes then hooked it back up and went over and presto chango she passed inspection and the light came back on on my way home
03stg2wrx is offline
post #10 of 13 Old 06-14-2010, 09:35 PM
So you just drive around with a CEL on all the time? Is there some reason you don't disable the CEL or do a manual fix?
Ryan
2009 STi - Cobb Stage 2
VisiX is offline
post #11 of 13 Old 06-14-2010, 09:51 PM
03stg2wrx's Avatar
yea I just drive around with it on, my tuner forgot to disable the code that reads for a cat in the rear o2 sensor and I dont feel like driving 2 hours away again at the moment for him to fix it, it has to flashed on the ecu to clear it completely
post #12 of 13 Old 06-14-2010, 09:54 PM
You should find someone local with a tactrix cable if your tuner is using open source. You can just pull the map off the car, disable the cel, flash it back and problem solved.
Ryan
VisiX is offline
post #13 of 13 Old 06-14-2010, 09:56 PM
03stg2wrx's Avatar
I dont think I have anyone around who can do that, I really wouldnt want a non professional to work on my map anyway really haha
