02 subaru tons of white smoke and oil out of exhaust! - Subaru WRX Forum
post #1 of 11 Old 04-08-2009, 05:52 PM Thread Starter
quick02subar is an unknown
I bought a 02 subaru wrx with 71,000 miles on it. on my way home the fogs machines went off in my exhaust i have never seen so much smoke and oil is in exhaust. compression test front left 95 back left 145 front right 140 back right 145. obviously the one cylinder is having problems where do i start ?
quick02subar is offline
post #2 of 11 Old 04-08-2009, 06:20 PM
03 CrazyTaxi's Avatar
I suggest a leak down test to see if you need a head gasket, piston rings, or new heads. That 95 is really low, that's the cylinder where your problem is obviously.
03 CrazyTaxi is offline
post #3 of 11 Old 04-08-2009, 07:20 PM
My guess is bad piston rings and/or piston. Hopefully no damage was done to the block itself. Regardless it needs to be torn apart for an exact diagnosis.
post #4 of 11 Old 04-08-2009, 07:58 PM
VD5505's Avatar
What is all done to the car for mods? I think it's time for the engine to come out and take it apart, perfect time to built it up stronger as well or if you are on a tight budget you can just replace what is wrong, My bet is that the piston is cracked and or the rings as well. I wonder if whoever owned your car before you turned up the boost the engine ran lean burned hot spots in the piston maybe took out the head gasket and thats where your coolant (white smoke) is coming from and then the piston broke and thats your oil prob. Just a guess at it.
VD5505 is offline
post #5 of 11 Old 04-08-2009, 08:11 PM Thread Starter
It has a upgraded turbo, perrin fuel injectors and fuel rail, aem fuel pump, dg catless exhaust,intake and front mount intercooler from what i can see. a mechanic said the same as you messed up piston... what should i do ? buy a long block from subaru ? rebuild this one ? find a used motor ? where do i find them at ? thanks for the help.
post #6 of 11 Old 04-08-2009, 08:23 PM
A bad piston doesn't necessarily mean a bad block. You should really take it to a trusty subaru mechanic and see the condition of it and then go from there. It depends if you are on a budget or if money is not a problem. You could always do a hybrid build with the 2.5 shortblock if money is not an issue.
post #7 of 11 Old 04-08-2009, 10:26 PM Thread Starter
Well it doesnt grow on trees around my house but, i would like to build the best possible motor i could. might as well since it will be out of the car anyways. how much money you talking ? where would i find the block ?
post #9 of 11 Old 04-11-2009, 12:33 PM
oldfartracer's Avatar
oldfartracer is more helpful than not
You could also go to your local dealership and order a STI short block.
oldfartracer is offline
post #10 of 11 Old 04-11-2009, 01:18 PM
VD5505's Avatar
That will cost more and alot of other places will throw in a free gasket kit as well. Go to this website this is where i bought my 2 STI short blocks and they are great people to do business with.
P&L Motorsports - Home
VD5505 is offline
post #11 of 11 Old 01-17-2010, 06:31 PM
busadave is an unknown
it might be a good idea to drop the down pipe and ck the turbo for oil,the seals may be blown.
busadave is offline
