02 sensor question - Subaru WRX Forum
 4Likes
  • 1 Post By boo-key
  • 1 Post By arcticscythe
  • 2 Post By jeddy
post #1 of 9 Old 06-24-2014, 12:18 PM Thread Starter
jeddy is an unknown
02 sensor question
okay so i bought a 02 sensor and without double checking myself before i bought it,the sensor is for 05-09 2.0L, after comparing the only difference that i can tell is that the connector has a different pattern, 4 pins and colors are the same. if i just swap connectors, is the sensor compatible?
jeddy is offline
post #2 of 9 Old 06-24-2014, 12:46 PM
boo-key's Avatar
Front or rear? Probably should trade it for the right one anyway.
BLAZE2099 likes this.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #3 of 9 Old 06-24-2014, 01:47 PM Thread Starter
jeddy is an unknown
its the sensor in the up pipe right before the turbo
jeddy is offline
post #4 of 9 Old 06-24-2014, 03:24 PM
arcticscythe's Avatar
Pretty good chance its the same but honestly its not worth the headache down the road when its not "exactly" the same. Its worth the drive back to swap it for the right one.
Epictofer likes this.
- Jason
arcticscythe is offline
post #5 of 9 Old 06-24-2014, 05:06 PM
boo-key's Avatar
As I stated in another thread, this one needs to be replaced with a oem replacement. I've replaced this one before with one from a parts store that didn't clear the cel but once replaced with oem everything was fine.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #6 of 9 Old 06-29-2014, 07:42 AM
dustminer is an unknown
if its in the up pipe its most likely the egt sensor !
dustminer is offline
post #7 of 9 Old 07-03-2014, 12:54 PM Thread Starter
jeddy is an unknown
the problem was i bought it on ebay so i figured i go ahead and try to use it. i cut and rewired the sensor(crimped and heat shrink) with the old sensor connector, its working alright so far. and it is the front a/f sensor, egt sensor is just downstream right befor the turbo. thanks for the advice guys
jeddy is offline
post #8 of 9 Old 07-03-2014, 01:33 PM
Jeddy,
Glad to hear its working, You might want to wrap that heat shrink with a thermal protectant. Most of my soldiering heatshrink is only good up until about 150 celcuis. Most of the time under hood temps are well below 150 but on hot days on the 405 freeway ive seen temps up to 220 at the intake end. It might be worth wrapping in some of that foil tape just to be safe.
post #9 of 9 Old 12-13-2014, 02:45 PM Thread Starter
jeddy is an unknown
well a few weeks after I installed the ebay sensor, It went bad... I bought the correct factory one. been working great for a few months now
boo-key and BLAZE2099 like this.
jeddy is offline
