Go Back   WRX Forums > WRX Racing Forums > Road Course/Autocross Tech
Old 07-08-2008, 07:33 PM   #1 (permalink)
wagonracer's Avatar
Timeslip: 9.999 @ 92.412
Reputation: wagonracer is known to be trustworthy and helpful wagonracer is known to be trustworthy and helpful
SCCA soloII classing ?
Allright, I'll admit it. I'm a total newb at autoX, and new to the SCCA way. I can't figure out where my wagon classes for SoloII. Here's the scoop on my car: '02 Subaru WRX wagon with Up pipe, down pipe, stock exhaust the rest of the way back, ECU re-flash, light weight main pulley, intercooler samco Y-hose, turbo inlet hose. Suspension consists of camber plates, front strut brace, Koni adjustable inserts, aftermarket springs, sways and endlinks on street radials. The car is classed TTD for NASA time trials.
Can anybody tell me what class I should register in ? thanks a bunch
Old 07-08-2008, 08:45 PM   #2 (permalink)
Reputation: WRXKidid775 is more helpful than not
itseither going to be ESP or SM im not sure on the pulley and intercooler hose and inlet hose. Everything else would put you in ESP just not sure about those. Both of those classes run big massive race tires, which are ridiculously better than street tires. I know your a good driver but race tires make even crappy drivers look good on the autoX course. You may want ot find out if your region has a Street Tire Modifier. It is hit or miss but the region I race in here has it. Its designated by a "T" in front of your class. It gives you back a little time in order to compete with the guys rolling on huge R compounds.
Robby
02 rex is gone.
I defected to an evo :)
Old 07-08-2008, 09:27 PM   #3 (permalink)
tom_noland's Avatar
Reputation: tom_noland is an unknown
Send a message via AIM to tom_noland Send a message via Yahoo to tom_noland
In the TN region im in SM. You need to log onto the region's web page or forum and find a post about classing your wagon.
Tom
'05 WRX Wagon
Cobb AP Stg 2
"Wagon power baby!!!!"
Old 07-09-2008, 09:57 AM   #4 (permalink)
Big Sky's Avatar
Reputation: Big Sky is known to be trustworthy and helpful Big Sky is known to be trustworthy and helpful
ESP w/ what you describe
things that knock you out of STX are the intercooler hose, ecu tune (in STX you can tune the ecu but only for timing and A/F- can't touch any of the boost paramters
the other "sticky" thing is there are new rules (actually a "clarification") concerning emissions- the old rule said you had to have one cat in place (didn't matter which one) and could be no further downstream than 6" of the furthest oe one. Now you can't run any cel defeaters- either mechanical or ecu- which people are finding out generally means running two cats (w/ the O2 sensor behind the last cat), in addition the have deemed the egt probe in the uppipe as emission equipment needed- so that means a gutted stocker or an uppipe w/ a provision for the egt probe.
the clarification basically sucks and has a lot of WRX folks migrating out of STX- which was probably part of the plan of the "clarification"
ESP has traditionally been the pony car class- camaros/mustangs- when fully prepped they are very formidable. ESP has no limit on wheel or tire width and R compounds are allowed.
What I like about ESP is that it matches up nicely for a car that is going to be used at the track- allows uprated radiators, uprated intercolers and you can fully tune the ecu including boost parameters.
Wagon Mafiosa
Old 07-09-2008, 02:28 PM   #5 (permalink)
wagonracer's Avatar
Thanks for the replies. I'm not likely to get super competitive with this, and am fine with being an underdog in ESP. Me and my wagon are ready to take on the pony cars, even with street radials ! I need to find out if the RG region has a tire modifier. My car probably would have been pretty well prepared for ESP before I de-modded it, and was still on DOT Rs. I guess if I get hooked, I might think about prepping it down to STX or max out what I can do in ESP, but for now, I'm just looking to have fun.
Old 07-09-2008, 03:17 PM   #6 (permalink)
Big Sky's Avatar
that's the best approach, see how you like it- your not that far off of STX if you decide to become more involved OR simply further prep for ESP
Wagon Mafiosa
Old 07-10-2008, 03:15 AM   #7 (permalink)
Best of luck to you wagonracer. Look forward to some great pics and interesting stories.
