-   -   Wideband (http://www.wrxtuners.com/forums/f70/wideband-31632/)
Babyshoes 11-17-2011 12:18 AM
Wideband
How essential is a wideband gauge compared to a standard A/F gauge? I was reading through the guide and figured Id work on getting gauges as my next step. Im going to pick up a turbo timer first, and then eventually the others listed. Most wideband ive seen are around 200 compared to the 60 or so for standard. After the gauges id like to try to move on to the engine management and get the cobb tune going. Will not having the wideband severely hurt my ability to read it correctly?
pzr2874 11-17-2011 05:59 AM
[quote=Babyshoes;271322]How essential is a wideband gauge compared to a standard A/F gauge? [B]VERY if you are tuning your own car[/B]. I was reading through the guide and figured Id work on getting gauges as my next step. Im going to pick up a turbo timer first [B]If you do, look at the Blitz dual TT, it has a few nice functions but is not really needed[/B], and then eventually the others listed. Most wideband ive seen are around 200 compared to the 60 or so for standard. [B]If you decide to pick one up, try to stay with Innovate and AEM[/B]. After the gauges id like to try to move on to the engine management and get the cobb tune going. Will not having the wideband severely hurt my ability to read it correctly? [B]The wideband is a necessity for tuning but not required for monitoring but if you are going to get one, the wideband is the way to go[/B].[/quote]
I would go with the COBB AP first before anything else IMHO.
brfatal 11-17-2011 06:22 AM
It's not essential at all and a turbo timer is a waste of money.
psinuse 11-17-2011 06:32 AM
Boost gauge is not required, but i'd look into it and engine management first and foremost. Don't spend money where it's not needed.
pzr2874 11-17-2011 08:58 AM
That Blitz TT is awesome. Especially if you need a boost gauge as it's DEAD on. Plus the other goodies make it a nice investment for 140.00.
My 2¢
psinuse 11-17-2011 09:12 AM
[quote=pzr2874;271344]That Blitz TT is awesome. Especially if you need a boost gauge as it's DEAD on. Plus the other goodies make it a nice investment for 140.00.
My 2¢[/quote]
You are prepared for the inevitable "ricer" comment from that right?:p
pzr2874 11-17-2011 09:31 AM
I had proof. hahahahaha.... I'll take the comment.
BUT
I did use it for almost everything it offered. Gauge, warm-up timer and lap timer. Especially when a nice gauge is ~130.00 anyways
PS... [COLOR="Lime"]I still have my wing.[/COLOR]
basco 11-17-2011 09:41 AM
^ Ricer
Babyshoes 11-17-2011 09:51 AM
[quote=pzr2874;271323]I would go with the COBB AP first before anything else IMHO.[/quote]
Shouldnt i have gauges though so i can gauge my tuning?
pzr2874 11-17-2011 10:17 AM
Other than AFR what gauges are you referring to ?
Babyshoes 11-17-2011 10:33 AM
the ones listed on the guide EGT A/F Boost. Are you saying A/F is really the only essential one needed for an accurate tune?
cwinterbower 11-17-2011 10:37 AM
I have zero aftermarket gauges in my stage 4 with a big turbo, it looks completely stock inside. Of course I used a wide band to tune afr, but I would never try to tune a car with a gauge. I guess I am not completely understanding the thread, but yes a wideband and other logging tools are necessary to tune properly, a gauge is far from necessary.
Babyshoes 11-17-2011 10:40 AM
Ah. Ive not messed with an access port yet, so i guess i was assuming you adjust your tuning by your installed gauges, but all that information is included in the access port im guessing?
pzr2874 11-17-2011 11:49 AM
Yes you can go off the AP for everything, except the AFR, well it's on the AP... but it's not a "true" reading.
Wrxsubie2008 11-17-2011 11:50 AM
The accessport will show you a/f readings but I would not recommend using it to base your tune of of as it uses the cars narrow band sensor in order to insure proper tuning you need a wideband sensor you do not need the Gauge as you don't need to be able to always see your a/f readings but u do need to be able to log the readings so that you can then look at them when tuning in order to base your tune off of so that you can make a accurate and safe tune for your car.
