what would happen if i did this - Subaru WRX Forum
post #1 of 9 Old 12-11-2008, 12:17 PM Thread Starter
05rex is an unknown
hey guys i just picked up my accessport and now im running stage 1 , I dont have a aftermarket downpipe i just have the cobb cat-back. What would happen if I went to stage 2 without the bigger downpipe. Has anybody ever done this?
05rex is offline
post #2 of 9 Old 12-11-2008, 12:39 PM
Why not try reading Cobb's map notes.They are there for a reason.......
dumdum is offline
post #3 of 9 Old 12-11-2008, 12:57 PM Thread Starter
05rex is an unknown
I just read the map notes on cobb and it didnt say anything negative or positive, can you be so kind and inform me great one.
05rex is offline
post #4 of 9 Old 12-11-2008, 02:04 PM
04paulieWRX's Avatar
04paulieWRX is an unknown
My assumption is that you would run rich. Going stage 2 increases the boost and therefore would have to increase the fuel to match it.
Honestly, its not worth it. you can find a used downpipe on nasioc for like 150 bucks. JUst throw one on there before you start messing around with the ecu.
04paulieWRX is offline
post #5 of 9 Old 12-11-2008, 02:52 PM
Images: 14
Labukas19 is more helpful than not
i forget who said it but someone on here said "it's like shoving a watermelon through a straw". thoguth it was pretty funny lol...
2001 COBRA
Labukas19 is offline
post #6 of 9 Old 12-11-2008, 04:49 PM
SuBeast's Avatar
SuBeast is on thin ice
!Laugh! it is pretty funny, but true. I can only image what kind of damage you'd cause by upgrading the ecu tune without the correct supporting modification..... My suggestion to the OP: Don't try it.
FAST
RELIABLE
CHEAP
Pick 2
2006 STi
1990 Toyota Hilux - daily
SuBeast is offline
post #7 of 9 Old 12-11-2008, 09:09 PM
Or try it and let us know what happens in a few months. I have seen this asked before, but no one try it.
post #8 of 9 Old 12-12-2008, 07:32 AM Thread Starter
05rex is an unknown
I dont think i want to be the test rat on this subject so I will just leave it alone
thankyou
05rex is offline
post #9 of 9 Old 12-12-2008, 09:38 AM
Doesn't work like that.Fuel is added accordingly to airflow calculated from the MAF.If I unhhoked my BCS and ran wastegate pressure without changing my mapping at all,my car would run perfectly fine and the proper fuel amount would be given to achieve the proper AFR.Plus if that was the case how do you think your car applies fueling when it's in vacuum?
That is actually more correct.Stage 2 raises the boost much higher and sooner.But it is very counter productive to try and do that through the stock DP and midpipe and could cause much higher EGT's than normal possibly.This would not be good for the preturbo cat in the up-pipe.
dumdum is offline
