-   -   v2 acessport for 05 wrx (http://www.wrxtuners.com/forums/f70/v2-acessport-05-wrx-48985/)
gunk007 05-07-2014 01:39 PM
I found an unmarried sub-001 v2 for sale ($400). It has everything. Is there a huge difference between a v2 and v3? I will run stage 1 for a while (maybe forever) and then upgrade to stage 2 hopefully at sometime. Please respond quickly before it sells! :)
thekamikaze kid 05-07-2014 02:24 PM
[quote=gunk007;452497]I found an unmarried sub-001 v2 for sale ($400). It has everything. Is there a huge difference between a v2 and v3? I will run stage 1 for a while (maybe forever) and then upgrade to stage 2 hopefully at sometime. Please respond quickly before it sells! :)[/quote]
i only have used the v2 but i believe the only differences between the two are the fact that you can view three differnt performance monitors, there is an on and off button so you can leave it plugged in when the car is off, and the uploading is faster on the v3. im sure there are other things. if you only want to load maps i wouldnt see why settling for the v2 would be a bad idea. i have the v2 and works great.
gunk007 05-07-2014 02:51 PM
Thanks
BLAZE2099 05-07-2014 03:14 PM
Talk him down to 350
arcticscythe 05-07-2014 05:53 PM
If you are planning on sticking with a stage 1 then make a low-ball offer and work you way to 350.
I have the v3 and I love the display, 6 gauges all day long but if you plan on installing stage 1 and putting it in the glove box then there's no reason to pony up the extra cash for a bigger screen. I cant remember what year but there are some older wrx's that also require a jumper to install new maps and log so i would double check that your model can do without, or that it will be included.
Welcome to the "i think im gonna be stage 1 for a while" group. Once that mod bug bites it never stops : )
brfatal 05-07-2014 11:05 PM
$400 is too much for a V2. That's what they ran used before the V3 came out.
