TXS UTEC Stage 1 - Subaru WRX Forum
post #1 of 6 Old 03-08-2003, 08:34 PM Thread Starter
Kobiyashi's Avatar
Kobiyashi is more helpful than not
TXS UTEC Stage 1
I recently purchased a UTEC Stage 1 and installed the ABC... I turned the boost to match the amount stated in the manual at 4500 RPM. Now everytime I shift from 1-2 and 2-3 and sometimes go TPS% 100 in 3rd I get 1-12 knocks for one logger line before it lows the timing. I have a Perrin CAI, HKS SSQV BOV, and the ABC/UTEC. I was wondering what I should do to remove the knocks, I've always run 93 octane, and in the last tank added an octane boost to try and remove the pre-det. Any advice or help would be greatly appretiated. If you would like you could give me a call at 540/239-2703 (ask for Julian).
-Thanks...
P.S. I've tried lowering the boost to just 14PSI as well as lowered the timing 2-3 through the 3500-5000 range without any luck (the latter of the two removed the knocks from 6-12 to 1-3)...
-Thanks Again!
Kobiyashi is offline
post #2 of 6 Old 04-01-2003, 12:03 AM
wrxratedII is an unknown
is the boost set at 4500rpm over 7psi? if it is then no matter what you do it will bang, 14.7 closed loop i run my max boost at 6psi, maybe try that.
wrxratedII is offline
post #3 of 6 Old 04-01-2003, 01:42 PM Thread Starter
Kobiyashi's Avatar
running 6psi?! Little bit more info please...
post #4 of 6 Old 04-04-2003, 11:26 PM
You state a TPS of 100 but do you have a 02 reading on that?
i have to run 0 advance in that range and also have to have a 02 reading of greater than 90 to stop the knock i like to keep it at 96 in that range to play safe, but those numbers are possum link readings don't know how accurate they are, but might give it a try.
post #5 of 6 Old 04-05-2003, 09:27 AM Thread Starter
Kobiyashi's Avatar
heh fixed a while ago, was the CAI ; it maxed out the injs
post #6 of 6 Old 04-16-2003, 11:16 PM
koki is an unknown
i dont have the cai have stage 2 and get the 1 to 12 knocks run at 16 boost on 4 gear 4500 rpm with the 93 octane we added more fuel to lower this but still some times does it wtfck!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
koki is offline
