Turboxs Stage 2 HELP!!! - Subaru WRX Forum
post #1 of 7 Old 03-25-2012, 08:46 PM Thread Starter
zblad is an unknown
Hello I installed a turboxs utec yesterday and I know they come rich and need some custom tuning. I figured the stage 2 map off the turboxs site would just basically plug and play and be good till I learned more about tuning. I ran stage 2 to and at about 4000 rpms with wot my check engine light blinks and feels like the car cuts out in 1st and 2nd gear. I was wondering if anyone had a tuned stage 2 map I could use. Or if someone could tell me what I need to change fuel, boost, timing or all 3. If someone could please help id greatly appreciate it if you need more info just let me know. THANK YOU
zblad is offline
post #2 of 7 Old 03-26-2012, 05:44 AM
Did you get the UTEC on the cheap?
No codes? Just a flashing CEL?
post #3 of 7 Old 03-26-2012, 11:10 AM Thread Starter
zblad is an unknown
I got the utec for cheap yes... And the check engine light flashes the log says it rich and is knocking i called turboxs and they said to mess with the timing i just have no clue where to really start im guessing right before the knock but do i change every single number ### thats like 50 numbers or do i just do like 4 and see if it changes it at all
zblad is offline
post #4 of 7 Old 03-26-2012, 11:45 AM
I wouldn't mess with UTEC at all. I'm not going to be any help.
Find a UTEC tuner (if you don't mind you ECU being "locked" after the tune)
Good luck
post #5 of 7 Old 03-26-2012, 12:50 PM
UTEC, not ECUTEK.
post #6 of 7 Old 05-09-2012, 02:18 AM
Alexmartynyuk's Avatar
Alexmartynyuk is an unknown
I will be posting a stage 2 basemap on rr shortly, I will pm you when its up on rr.
Alexmartynyuk is offline
post #7 of 7 Old 05-27-2012, 12:31 AM
never mind, I missed the part that you are using a utec.
