turboxs - Subaru WRX Forum
post #1 of 11 Old 11-28-2007, 10:31 PM Thread Starter
ScooobaSeth is an unknown
turboxs
Ok guys to make a long story short a wrx came in on a trade at my dealer that was beat. body was mostly hit and it had no second gear. upon inspection of it I found a turboxs controller hooked up to it. it was over the ecu...then had a plug with a wire that went to some switch that goes from 1-9. Looking at the side of the turboxs box, not where the ecu harness plugs into...but the other side has; a 12 pin connector, little red dial, serial cable connector, and ground wire, then some sort of plug, i dont know what is it for. there was nothing pluged into it.
Now looking at the wires i took out, the one with the 12 pin connector has the dial switch on it. It also off of each end has a red and a black wire that are just taped up. Then the other one is just the serial cable.
I looked on the website and cant find anything about it. the box is grayish. can someone point me in the rite direction?
Seth
04 Wagon
ScooobaSeth is offline
post #2 of 11 Old 11-29-2007, 04:16 AM
Sounds like a Utec.Take a picture.
dumdum is offline
post #3 of 11 Old 11-29-2007, 05:29 AM Thread Starter
Ok well its a utec.....
I cant seem to find the user manual. It says its on the website, and i ended up downloading some version 5.8b something, which I dont think I can use. Can anyone steer me in the rite direction?! Dont I need software on my laptop to do this? It says I can plug everything in and set the dial to 1 and its a stock performence setting? anyone hear of this? What do I need at this point?
04 Wagon
post #4 of 11 Old 11-29-2007, 05:34 AM
Answered your other post in clubwrx...
You need to slow down and read......
Zip File WRX UTEC v5.8 above contains: WRX UTEC v5.8, M16 Flash V124, WRX-STI Manual, Update Notes
http://www.turboxs.com/utecwrxupdate.htm
dumdum is offline
post #5 of 11 Old 11-29-2007, 11:05 PM Thread Starter
do you think it could be a problem if i dont have that abc boost controller.
04 Wagon
post #6 of 11 Old 11-30-2007, 07:03 AM
What do you have in it's place?
dumdum is offline
post #7 of 11 Old 11-30-2007, 02:24 PM Thread Starter
well my car is stock, so there would be nothing there. anything i can use to put in its place or do i not even have to have it?
04 Wagon
post #8 of 11 Old 11-30-2007, 05:02 PM
SWFL Scooby's Avatar
SWFL Scooby is an unknown
I don't use mine- as long as you want to use the base maps from the internet, you don't need it.
D-Rock
Under constant pressure
SWFL Scooby is offline
post #9 of 11 Old 11-30-2007, 06:07 PM Thread Starter
well i got all the stuff hooked up to my computer. it first loaded up and i saw everything, but i couldnt move around or do anything. i unplugged it and started over again and now i just get a blank white screen, but it says connected. i dont know whats wrong!!!
04 Wagon
post #10 of 11 Old 11-30-2007, 07:06 PM
Tons of Utec info... http://forums.nasioc.com/forums/forumdisplay.php?f=141
dumdum is offline
post #11 of 11 Old 12-02-2007, 05:17 PM
Or call turboxs at 301-977-4727
D-Rock
