turbo upgrade - Subaru WRX Forum
post #1 of 7 Old 01-10-2008, 03:36 PM Thread Starter
turbo upgrade
hello everyone, i have a 07 2.5 WRX with ecutek, K&N tayphoon, catless downpipe, center pipe and turbo back, and a fuel pump. Im running around 270HP and i have around 18.5psi boost. I want to upgrade my turbo now, im aiming for around 320HP. the question is, if i upgrade my turbo and stay with around 18.5psiwill i have to change my pistons and put reinforced ones?? or can i keep my car like it is and just install a bigger turbo?? will i have to worry everytime i drive my car that my engine might break? thx
nicolas316 is offline
post #2 of 7 Old 01-10-2008, 03:39 PM
Longshot's Avatar
If your pushing 320 to the wheels on a 2.5L you'll be fine. Just make sure your injectors will cover you depending on how big of a turbo you get.
DTRacing Tuned
Longshot is offline
post #3 of 7 Old 01-10-2008, 03:41 PM
TDub's Avatar
Send a message via AIM to TDub Send a message via MSN to TDub
I do believe the stock internals should be ok at 320 hp. From what I've read, i'd be more worried about the transmission going than the stock internals at that stage.
TDub is offline
post #4 of 7 Old 01-10-2008, 04:17 PM Thread Starter
so you guys think i should go for a bigger turbo without worrying about my engine internals?? all ill need with the turbo is a bigger intercooler??
post #5 of 7 Old 01-10-2008, 06:21 PM
Longshot's Avatar
Turbo, Injectors (depending on turbo size), Pump, IC
DTRacing Tuned
Longshot is offline
post #6 of 7 Old 01-10-2008, 07:17 PM
SWFL Scooby's Avatar
you will also need a protune to get the full effects of an upgraded turbo
D-Rock
Under constant pressure
SWFL Scooby is offline
post #7 of 7 Old 01-16-2008, 09:44 PM
I was also upgrading my turbo and was wondering what all i am missing and should be i worried about breaking? And what ecu would you recommend? I have fp red turbo ,inlet hose for it , fmic, fuel pump and going to buy 800cc injectors.
johngotti187 is offline
