Turbo???? - Subaru WRX Forum
post #1 of 3 Old 11-14-2007, 02:10 PM Thread Starter
Turbo????
as you guys most probably know my car is a 2.5L WRX with exhaust and K&N tayphoon intake and ecutek map. now im thinking of a better turbo ### mine is still stock. Can i put a bigger turbo with my stock pistons, intercooler, and fuel injectors? and leter on upgrade the rest? ### doing all together is costly.???
nicolas316 is offline
post #2 of 3 Old 11-14-2007, 02:32 PM
BAMBO's Avatar
For sure you can!! However, IMO there are only a couple of turbos that I would use. I'll use myself as the example. When I started to Mod my rex, I ran a IHI VF30 Turbo with a very agressive tune. so agressive in fact that I had to back the boost down in the high rpm's(ran 19PSI till about 6K then back it down to about 10.5PSI) so that I didnt lean the motor out! I basically maxed out injectors, fuel pump and clutch(mind you it was on its way out anyways). BUT before I upgraded the turbo, I already had a turbo-back(UP, DP mid and catback ... just recently added headers) as well as the intercooler Y-pipe.
So long story short, it was a nice setup for a short period of time. I personally wouldnt run it for too too long ... but it can be done! I would run a VF30,34 or 39 if I was goign that route. but at a minimum, I would have the full exhaust and y-pipe before up-ing the turbo! At least thats my opinion about it all!
oh PS -- not that I like to be the bearer of bad news, but you really dont need the intake till you're about 300hp-350hp at the crank! I have one as well but you really dont need it! jsut for future knowledge!
BAMBO is offline
post #3 of 3 Old 11-14-2007, 02:38 PM Thread Starter
thanks for that man. so i could install a bigger turbo on stock intercooler and same pistons for around 5 to 10k miles? it wont do any harm to my car?
