Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Tuning & Engine Management
Old 05-01-2009, 03:12 PM   #1 (permalink)
Reputation: Chase is known to be trustworthy and helpful Chase is known to be trustworthy and helpful Chase is known to be trustworthy and helpful
Time for monitoring
I need to get my gauge on! Seriously, I don't even have a boost gauge, and I'm scared. So looking into it, I found the cheapest clock delete gauge pods are like $50,and I thought to myself, wow, that's expensive for a thin plastic mold. Then I searched here for decent gauge brands and just about crapped my pants when I saw the prices for the decent brands even on ebay(greddy, plx, defi, etc).
I want a wideband, oil pressure, fuel pressure, and boost gauge.
So walk me through this please. What brands are not stupid expensive but look and act like they are? Where do I get them? I was also thinking with that kind of pricing for 4 gauges and a couple pods, maybe it would be more cost effective to get an electronic head unit that can monitor the afore-mentioned. But this I haven't even looked into at all yet. I definately don't want to spend more than a few hundred right now, but if a head unit were worth it, I could wait.
Stage 2 Cobb OTS map 2004 STi
Soon to be Stage 1 2001 Corvette
Old 05-01-2009, 03:21 PM   #2 (permalink)
Car: 04 WRX
Reputation: 04wrxhart is an unknown
Uhm gauges are pretty expensive. All the nice ones ive seen are 100-150 for just the gauge and the wires etc. As far as a gauge pod goes, you could also mod your clock pod into a gauge pod with some bondo, fiberglass and a shit ton of sanding. I plan on doing mine one of these days when i can afford some gauges that look decent. But you shouldnt worry about it to much, if your car does something its not suppose to it will let you know via cel.
Old 05-01-2009, 03:30 PM   #3 (permalink)
Well that's the point though man, When it blew a 2 inch chunk out of the side of my piston because it had been running lean, it let me know via cel that it was time to spend $2000 rebuilding it. I want some advance notice in the future.
I don't mind the pod expense, just curious mostly about gauges.
Old 05-02-2009, 12:52 PM   #4 (permalink)
Fine, I'm buying glowshift gauges because it's like 120 for 3 unless someone says otherwise. Is anyone running them that likes them? Glowshift is pretty big, so they've got to make at least decent gauges, right?
Old 05-02-2009, 04:12 PM   #5 (permalink)
I would go with prosport over glow shifts. Several people on here have ran the prosports and like them. Also heard that they have great customer service.
Old 05-02-2009, 09:00 PM   #6 (permalink)
glowshifts suck, your are better off with out one. Prosports are the way to go, super cheap and they are accurate. Green Gauges- Prosport Gauges WRX Subaru gauges
the wideband is going to be the most expensive, expect to pay around 275 for a good gauge and sensor.
Old 05-03-2009, 03:16 AM   #7 (permalink)
Thanks guys, that's exactly what I was looking for. I appreciate it.
Old 05-03-2009, 08:30 AM   #8 (permalink)
So your woried about having to spend $2000 on another blown engine so your going to buy the cheapest gauges possible?You really don't even need a fuel pressure gauge.Oil,EGT,boost/vac and maybe something like a TurboXS knock sensor or wideband.I run one of these in my car(PSI3)
Aarg matey!
ECU Pirated by RomRaider
Old 05-03-2009, 12:31 PM   #9 (permalink)
oldfartracer's Avatar
Reputation: oldfartracer is more helpful than not
AEM Uego wideband, Tur Boost and Oil Pressure is what I run, I also data log.
But I would say an AFR or EGT, boost and oil pressure will keep thing in check. Just remember that by the time the gauge shows a problem, it's normally too late.
Old 05-07-2009, 12:22 PM   #10 (permalink)
blk05WRX's Avatar
Car: 05 WRX
Reputation: blk05WRX is more helpful than not
Anybody know if there are open ports to plug some of these gauges into? A friend's EVO had two open ports that he could plug an Air/Fuel ratio gauge into. Is it that easy on a WRX?
I know that boost is pretty easy b/c you just tap into a vacuum line. I want to get 3 gauges, but they're more for show, so I'd like to know which are the most straight forward to install. For an EGT, you have to drill into the exhaust, right?
Old 05-07-2009, 01:49 PM   #11 (permalink)
For a wideband, yes. You have to tap a hole and weld in a nut to thread into.
I don't want the cheapest gauges possible, but I want some that aren't overpriced. There's no reason to spend a grand doing this. I'll go with prosport.
Old 05-07-2009, 02:32 PM   #12 (permalink)
Reputation: wrx9wagon is a helpful contributing member
What would be the cons of just running Dashhawk?
Old 05-07-2009, 10:18 PM   #13 (permalink)
Chase where do you plan on mounting them? Post up some pics also when you get them installed.
Old 05-07-2009, 11:18 PM   #14 (permalink)
glowshift's clock delete pod is only 40 dollars on their site, and it's not the aggressive hoodscoop style one, it's very lowkey and I like it. For the actual gauges I'll go with prosport, and have the bung welded in for the Wide band next time I take my car into RallyTek.
Old 05-07-2009, 11:48 PM   #15 (permalink)
I kind of like the clock delete myself, but just not sure. Kind of been kicking around the idea of having 6 or 7 gauges total, just not exactly sure (I mean I know what ones I really want, EGT, boost, and wideband), or when I will be getting mine.
