Thinking about a pro-tune as my next step... - Page 3 - Subaru WRX Forum
post #31 of 36 Old 09-24-2010, 02:08 PM
Aluminum driveshafts also dont fit as well as the stock one does. You usually have to modify your transmission tunnel (at least the ones I have looked at you do). Go Carbon Fiber if you are really serious about it, just my two cents.
post #32 of 36 Old 09-24-2010, 03:34 PM
Driveshaft shop aluminum shafts are rated to 150mph, cost $450-500..... I only go that fast when I'm at the salt flats.
CF is a very nice option - smaller diameter than aluminum so a smaller moment, couple lbs heaver, no speed limit... But they cost $1,500 new.
post #33 of 36 Old 09-24-2010, 04:34 PM
Originally Posted by RcrsWetDream View Post
Yeah I'd expect at least six grand for a proper tranmission build.....
Out here, there's a good enough guy at a dealership that you order the gears, and he'll put them in, and very well. Now just doing the gears moves the weak link to the diff's and axles. If you want to do it right, get gears, input shaft, clutch/fly, axles, and front diff. I'm even going to do my drive shaft while I'm at it... Saves about 20lbs going aluminum.
mine was 10ish
post #34 of 36 Old 09-24-2010, 05:12 PM
Dog box?
post #35 of 36 Old 09-27-2010, 10:43 AM
I can hit 130 in 5th before I reach 7k rpm with my new mods....and I still have a whole another gear left. So, that limit would passed in another gear and a long straight situation for me.
post #36 of 36 Old 09-27-2010, 03:24 PM
I hit 142 at about 5500 rpm's in 5th gear.... The engine I'm building is going to rev to 8k, so I'll still have plenty of speed to gain. My only issue is when in the hell am I going to hit 150.... Besides my random trips to the salt flats, never. I may be moving away from SLC before too long as well so that takes my chances to zero.
