To TGV delete or not to TGV delete 2017 WRX 2.0 - Subaru WRX Forum
post #1 of 2 Old 01-08-2017, 06:20 PM Thread Starter
Brian Hamm is an unknown
I know there is tons of information about this mod for the 2015 and I think the 2017 is basically identical but I'm wondering if anyone with a 2017 has done the TGV delete yet? Or if anyone has any thoughts on if I should wait? Can't seem to find anything on the 2017.
7k miles
Cobb AP Stage 1 ots stock map
The TGV Delete I plan to get is from Turn In Concepts 95$
They also released a 91 octane stage 1 tune for the cobb ap (or so i'm told) which I know would be required.
Thanks guys!
Brian Hamm is offline
post #2 of 2 Old 01-12-2017, 11:25 AM
RoboTuner is a helpful contributing member
Where are you located? West coast fuel is crap so careful. TGV deletes allow slightly more air, so you OTS (crap map) won't work well with anything else. Run a stage 2 91 map and use 93, it may sound weird at first but think about it, it's looking for more air, so more fuel will be used. And yes, other than some tweaks the 15 wrx w/ FA20DIT is the same, just test at light load and slowly check your logs and gauges when tipping in more a bit at a time. If your DAM drops, you're doing something wrong.
Check out Cobb's infosheet about what to watch for and familiarize yourself with their product!
RoboTuner is offline
