Check on Cobbs site. I think all you hav to do is submit a form and they can/will send it to you now. Unless things have changed again. And the "12" tgv DTC codes are all associated with rmoving the tgvs. There will be 12 codes you would need to delete to have the code(s) go away and run properly.
