target boost - Subaru WRX Forum
post #1 of 8 Old 03-02-2012, 06:20 PM Thread Starter
target boost
hi guys new to this forum. i have a 03 wrx with tbe uppipe and filter.ive owned this car for about 6 months now and other than the mods i listed it supposedly doesnt have tune ive done a couple logs. my target boost is reading 18-19 psi wgd is in its 90s iam 16 all the way but manifold pressure(psi boost) is 15.7. im using romraider. with the info ive given wouldnt you think it has been tuned already?do i have to adjust my wastegate arm? help please
pipe1 is offline
post #2 of 8 Old 03-02-2012, 07:01 PM
Yes it has been tuned. Start by checking for a boost leak.
dumdum is offline
post #3 of 8 Old 03-03-2012, 01:37 AM Thread Starter
the thing is that it seems to be acting normal goes up to 15.7 then will slightly drop to about 14.9 at about 6500 rpm and dont really here any noises. are there any methods to check for minor leak? thanks for quick feedback im already liking this forum
pipe1 is offline
post #4 of 8 Old 03-03-2012, 09:47 AM
bad grocerygetter's Avatar
Just put some soapy water in a squirt bottle. Spray down any hoses that are part of the bcs. Look for bubbles
Kevin.
bad grocerygetter is offline
post #5 of 8 Old 03-03-2012, 12:47 PM Thread Starter
i went out for a couple of logs and disconnected the bcs and left the t open. the boost went up to 20.4. i dont think it would reach that boost if i had a leak. or?
pipe1 is offline
post #6 of 8 Old 03-05-2012, 06:01 AM
^Don't do that... not a good thing at all
You could still have a leak....
post #7 of 8 Old 03-05-2012, 04:54 PM Thread Starter
ok so when you say boost leak meaning on the intake side of things or on the bcs and vac hoses.cause me disconnecting the bcs would be just eliminating the solenoid cause without it just slightly passed the boost target.sorry guys i am newbie so be abit patient with me. thanks
pipe1 is offline
post #8 of 8 Old 03-06-2012, 05:40 AM
Anywhere
Check under the TMIC, after the MAF(Turbo inlet). Heck, even the gasket under the BPV.
