sti shortblock and '02 wrx ecu???? - Subaru WRX Forum
post #1 of 9 Old 04-19-2008, 10:03 AM Thread Starter
darthsofearu is an unknown
i recently thru a rod and am now buying a new sti 2.5L short block for my '02 wrx. what do i need to do for the ecu seen as how it will be a hybrid motor(wrx heads with sti shortblock). any help would be great. i have searched for the answer and have had no luck that is why i am finally posting. thanx p.s.
i dont plan on getting anymore power than i already have
darthsofearu is offline
post #2 of 9 Old 04-19-2008, 11:54 AM
Jave's Avatar
Jave is more helpful than not
I answered in the other thread that you asked in. You will have more power by default due to the higher displacement. Your stock turbo will run out of breath up top.
You need a custom tune
bigger injectors(modded stockers)
bigger turbo
new timing belt
new water pump and oil pump recommended
other assorted items.
I did my hybrid build on 6k but it could be done way chaper if you shop around a bit and find good deals
▼SbiΣ Mi▼
Jave is offline
post #3 of 9 Old 04-19-2008, 01:22 PM Thread Starter
i have already done 565cc, 16g, fmic, and reflash. i just need to know what i need to with the ecu when i install the sti shortblock if anything. thanx again
post #4 of 9 Old 04-19-2008, 01:23 PM Thread Starter
oh and i just did the water pump, timing belt and tensioner. so that is done too
post #5 of 9 Old 04-19-2008, 02:48 PM
Just in terms of the ECU, you need to remap it due to the larger displacement.. You can still run the 2.0 ECU with an add on system like Cobb or Enginuity (sp?)..
post #6 of 9 Old 04-19-2008, 06:10 PM
Boostbuddy's Avatar
Boostbuddy is an unknown
You can use the EJ20 ECU with the EJ25 short block and EJ20 heads with a reflash no problem..but I have also seen great success with using a reflashed ECU (ECUtek) with the UTEC...but if you are going to go through all that might as well get a standalone unit.
Boostbuddy is offline
post #7 of 9 Old 04-19-2008, 07:19 PM Thread Starter
sweet. i was hoping u would read this lil shoaf. so i already have the cobb ap version 1. would that still work? cobb should have a map for that dont ya think?
post #8 of 9 Old 04-19-2008, 08:52 PM
i dont think they will. I would want a custom tune after spending all that money on your motor.
cobb . wrx accessport . map listing
nagyhead is offline
post #9 of 9 Old 04-19-2008, 11:59 PM
toecutter's Avatar
toecutter is an unknown
Just did this on my 02 WRX.
I got a Cobb AP and some maps to get me going from IA performance IA Performance - Automotive Service & Performance Parts - IA Performance ask for Gabe.
Using the map while I'm running in the engine, then will get a custom tune.
toecutter is offline
