Stage 2 mods? - Subaru WRX Forum
 4Likes
  • 4 Post By boo-key
post #1 of 8 Old 08-31-2013, 11:12 PM Thread Starter
05wrxwagonnoob's Avatar
Stage 2 mods?
Do I need to delete the cat in my uppipe to go stage 2?
Also is a new downpipe manditory?
05 wrx wagon
05wrxwagonnoob is offline
post #2 of 8 Old 08-31-2013, 11:37 PM
thekamikaze kid's Avatar
I believe the cat deletion is not necessary, but the down pipe is, check the Cobb notes for the map u r using if u r using a Cobb ap. to go to stage 2. Most ppl will recommend the up pipe deletion tho, I assume your year has the cat.
thekamikaze kid is offline
post #3 of 8 Old 09-01-2013, 05:16 AM
boo-key's Avatar
^correct. Stick to the map notes if using a ots map.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #4 of 8 Old 09-01-2013, 08:39 AM
Yes, an up-pipe is absolutely required for stage 2 and up.
post #5 of 8 Old 09-01-2013, 10:41 AM
boo-key's Avatar
If it was absolutely necessary Cobb would have it in their map notes which, I saw no mention of. Very very highly suggested but not absolutely necessary, unless I overlooked something in the notes. Personally I would make it my first mod, even before a catback.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #6 of 8 Old 09-01-2013, 01:54 PM
A basic Stg. 2 car consists of Turbo back exhaust, which includes, DP and a cat back exhaust. I highly recommend removing the catted up-pipe and replacing it with one from either a 04-07 STI, 06-07 WRX, LGT, FXT or an aftermarket one. Then of course you'll need a tune and how ever you do that is your choice, Cobb AP, Open source or some other form of EM.
post #7 of 8 Old 09-02-2013, 07:32 AM
People have also lost motors due to advice on Cobb products that they did not give.
It is absolutely required. A catted up-pipe while stock is a bad idea. Higher stage 2 EGTs will eat that cat, and he will end up replacing both it and his turbo sooner rather than later.
post #8 of 8 Old 09-06-2013, 06:07 PM
boo-key's Avatar
Just had to
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
