Ok so here go the noob this is a base stage 2 utec map right from txs site.
Just to get me started at least.
Mods include tsx ti TBE,Race Pipe, and short ram, (Gt Spec headers and U/P hope by this weekend there on my living room floor,good spot right)
Anyway
1383 -9.8 1.1 0 00 00 14.9 +12.9 12.4 ECU. +0.0 ECU. 1.3
2686 -4.9 2.3 11 00 00 14.9 +15.7 11.9 ECU. +0.0 ECU. 2.3
2801 -3.6 2.4 12 00 00 13.9 +33.2 13.4 ECU. +0.0 ECU. 2.4
2952 -3.4 2.4 12 00 00 13.9 +32.9 13.8 ECU. +0.0 ECU. 2.4
3121 -3.2 2.4 12 00 00 14.3 +33.2 14.2 ECU. +0.0 ECU. 2.5
3258 -3.2 2.5 12 00 00 14.3 +32.9 14.7 ECU. +0.0 ECU. 2.5
3425 -3.2 2.5 12 00 00 14.7 +33.5 15.2 ECU. +0.0 ECU. 2.6
3615 -3.4 2.6 12 00 00 14.7 +33.8 16.3 ECU. +0.0 ECU. 2.6
3728 -2.4 2.7 16 00 00 14.9 +34.2 18.8 ECU. +0.0 ECU. 2.8
4020 +3.1 3.1 33 20 00 16.4 +28.1 31.0 +20.2 -0.5 200.00 3.3
4380 +8.0 3.5 57 50 00 15.2 +15.8 50.1 +19.0 +1.6 255.00 3.7
4789 +11.3 3.8 77 60 00 rich +13.3 65.4 +20.1 +1.5 312.50 3.9
5367 +12.1 4.0 86 70 00 rich +18.8 83.5 +21.0 -0.2 340.00 4.0
5807 +12.3 4.0 96 70 00 rich +20.4 91.6 +21.3 -0.9 350.00 4.0
6325 +11.9 4.1 97 70 00 rich +24.0 92.2 +22.0 -1.3 350.00 4.0
6587 +11.9 4.1 78 70 00 rich +25.8 93.9 +23.0 -1.4 350.00 4.0
6816 -8.5 2.0 0 10 00 rich +10.2 8.1 ECU. -1.4 ECU. 1.6
6313 -3.6 2.3 42 10 00 17.6 +41.3 44.2 +35.2 -1.5 ECU. 3.4
4866 +9.0 3.9 89 50 00 rich +17.8 86.7 +18.6 +0.1 345.00 4.0
4438 +17.6 3.9 98 100 00 rich +9.0 81.4 +17.0 +3.0 350.00 4.0
4675 +15.5 3.8 98 90 00 rich +9.6 81.0 +18.6 +2.7 350.00 3.9
4816 +14.1 3.9 98 80 00 rich +12.0 80.7 +19.6 +1.5 350.00 3.9
5035 +13.7 3.9 98 70 00 rich +14.7 81.6 +21.0 -0.1 350.00 3.9
5175 +13.7 4.0 97 70 00 rich +16.0 88.1 +21.0 -0.1 350.00 4.0
5446 +14.1 4.0 98 80 00 rich +17.4 91.3 +21.0 -0.3 350.00 4.0
5630 +13.7 4.1 98 70 00 rich +19.1 92.4 +21.0 -0.6 350.00 4.0
5737 +13.3 4.1 97 70 00 rich +19.6 93.2 +21.0 -0.8 350.00 4.0
5952 +13.1 4.1 97 70 00 rich +20.6 96.2 +21.7 -0.9 350.00 4.1
6184 +12.9 4.1 97 70 00 rich +21.6 95.6 +22.0 -1.0 350.00 4.0
6485 +12.7 4.1 68 70 00 rich +24.0 95.3 +22.3 -1.4 350.00 4.0
6720 -9.1 1.9 0 10 00 rich +10.5 8.4 ECU. -1.5 ECU. 1.7
6325 -0.8 2.7 75 10 00 14.7 +41.7 57.5 +29.5 -1.5 202.50 3.6
4273 +12.7 4.0 97 70 00 rich +10.6 91.6 +17.0 +2.9 350.00 4.0
4629 +18.2 4.0 98 100 00 rich +9.7 93.7 +19.0 +2.8 350.00 4.0
4789 +16.8 3.9 98 90 00 rich +10.4 85.6 +18.7 +0.4 350.00 4.0
4816 +15.5 3.9 98 80 00 rich +10.7 86.1 +19.3 +1.2 350.00 4.0
4866 +15.1 3.9 98 80 00 rich +13.6 82.8 +19.8 +0.2 350.00 4.0
5027 +14.9 4.0 98 80 00 rich +14.6 87.7 +20.7 -0.1 350.00 4.0
5144 +14.5 4.0 92 80 00 rich +16.1 90.0 +20.9 -0.1 350.00 4.0
5128 +3.5 4.0 0 50 00 rich +37.2 19.0 ECU. -1.9 250.00 1.8
Through 1,2, part way 3rd
Car pulled out off county side road
I was a little woried about the Inj. duty
and the high boost spikes (will these get worse in 4th and 5th gear?)
also the lean spots at shift points Normal?
What do you guys see?
(Other than bad shifts and not hitting the redline)
And before you yell at me what Wideband do you recomend and can i use it with the utec?
Oh i dont have a egt either Now you can yell at me.
Weather was typical Indiana Cold 32* and clear
Anyway
