Stage 1+ sf not hitting target boost - Subaru WRX Forum
post #1 of 2 Old 04-17-2017, 10:21 PM
Chasek40
Guest
Posts: n/a
Hey guys. Im new to the tuning and subaru scene. I have a 2011 wrx and im runnimg cobbs stage 1+ sf. I know cobb says you should 17.5 psi on 93 octane which is what i run. I logged my car the other day how cobb recommends and my car wouldnt boost above 14.5. I then tried the hwg map and only hit 15.5? Ive already replaced the tmic to tb hose with one from cobb and ive also checked all the vaccum lines with no luck? Does anyone have any ideas? Im about to take it to a shop for a leakdown test but i figured id try my luck on here first.
post #2 of 2 Old 04-18-2017, 11:59 PM
Ruso's Avatar
Ruso is more helpful than not
What is your altitude?
You should check to see what the target boost variable is too as the ECU will decrease boost for things like Intake Temp, Altitude and a few other factors.
Good Luck!
Ruso is offline
