Silly Question - Subaru WRX Forum
post #1 of 4 Old 11-15-2011, 10:01 PM Thread Starter
Babyshoes is an unknown
Silly Question
So after reading up, ive found that a tune is most likely what I need to solve my MAF (Too lean) code from my CAI. The guy who had the car put a CAI and exhaust on the car but i have no idea what kind of CAI or what all the exhaust involves. But anyways, on to the question which may be somewhat dumb, but if i get this thing tuned for my current setup and reset/unplug the battery for one reason or another and let it reset, is that going to reset everything back to stock, which means ill have to pay to get it tuned again? or will the computer remember the tuning.
Babyshoes is offline
post #2 of 4 Old 11-15-2011, 10:17 PM
cwinterbower is more helpful than not
No, the main map goes in the part of memory that is static, it is "burnt" in. Only a reflash would change the tune.
cwinterbower is offline
post #3 of 4 Old 11-15-2011, 10:42 PM
There are two kinds of maps. Realtime and Reflash. Realtime will basically be what your car adjusts to your driving habits and can be lost when you pull the power off the battery terminals. The reflash can not be lost unless you flash a new tune or if the reflash memory some how gets screwed up. Which wouldn't be the easiest thing to do because it would have to out right fail or fail while flashing a new tune onto it. Hope that helps.
post #4 of 4 Old 11-16-2011, 06:21 AM
Just put the stock air intake on it and save yourself alot of hassle.
