Silicone Hose question HELP!!!!! - Subaru WRX Forum
post #1 of 8 Old 11-20-2011, 09:59 PM Thread Starter
WRXInfantryGuy's Avatar
i have a 07 wrx can i use a intercooler hose kit if on the website it says its for a 02-05 wrx
TJ Butler
WRXInfantryGuy is offline
post #2 of 8 Old 11-21-2011, 12:23 AM
It should work fine.
Kjott21 is offline
post #3 of 8 Old 11-21-2011, 01:01 AM
It may be slightly short because the 06-07 WRX/FXT used a smaller TMIC
post #4 of 8 Old 11-21-2011, 06:52 AM
If I'm not mistaken, the 02-03 IC is WAY different than the 06-07.
The metal Y pipe will not bolt up to your stock IC and the elbow will not reach as Matt stated.
post #5 of 8 Old 11-21-2011, 09:08 AM
My wifes 05 TMIC is very different than my 07 stock TMIC (let alone my TurboXS now in use, lol.)
post #6 of 8 Old 11-21-2011, 11:09 AM
I was wrong it won't work. You need one specifically for the 06-07 WRX.
Kjott21 is offline
post #7 of 8 Old 11-21-2011, 06:02 PM Thread Starter
ok thanks for the help.
TJ Butler
post #8 of 8 Old 11-21-2011, 08:29 PM
blk05WRX's Avatar
You can get a "universal" 02-07 kit on ebay for around $60. I got one when I put on my STI intercooler. You'll have to do a bit of trimming here and there, but it worked for me.
A word of warning that the silver gaskets that come with it are crap. You'll want to pick up the black paper gaskets from Subaru or a local shop for a few bucks. I had a boost test done at a local shop after I installed it and the silver gaskets were leaking at boost above 15psi.
02-07 TMIC Intercooler WRX Sti Y Pipe Kit Polished | eBay
2005 WRX Cobb Stage 2
2009 Outback
blk05WRX is offline
