real electric supercharger? - Subaru WRX Forum
post #1 of 5 Old 01-17-2010, 08:55 AM Thread Starter
Is there such thing as a real electric supercharger? There are alot of ebay ones which sell for $30+ and I looked at some of the seller's feedbacks and it looked like most people were satisfied about what they bought. I also googled Electric Supercharger and found this supercharger selling for $199. How would I know which one works and which one doesn't?
Thanks
rocket2050 is offline
post #2 of 5 Old 01-17-2010, 12:42 PM
That just looks like a bad idea, especially on an already FI vehicle... Slap it on and let us know what happens (or how long before kaboom).
post #3 of 5 Old 01-17-2010, 03:45 PM
04paulieWRX's Avatar
definitely not worth it on a turbo charged vehicle.. there are real deal electric superchargers but they are a couple of thosuand dollars. the ones you see on ebay are crap
04paulieWRX is offline
post #4 of 5 Old 01-25-2010, 06:23 PM
I think you may want to read this thread from nasioc (Electric turbos? Why not? - NASIOC). It is exactly what you are looking for, here are the pro/cons:
Cons
*Will draw a massive amount of power from your alternator
*Most electric motors can't create the same amount of psi as an exhaust driven one
*Electrical motors are not efficient
*Wasted exhaust gases
Pros
*Could possibly reduce spool time
Originally Posted by oversoul View Post
Somebody in a magazine has already tried one of these. I don't remember which. They found that it did work, but only made a little under a 1 psi of boost. It did increase HP, but the unite that they tried cost like 800 dollars. That's not a lot of power verses cost. A Re-flash was cheaper and made more power.
Originally Posted by HyperSl4ck3r View Post
You could not be more wrong... Look at a gas turbine engine. Turboprop, turboshaft, turbojet, turbofan... ALL of them spin the ENTIRE engine, hundreds of pounds of metal, spinning at 10,000+ RPM, off of exhaust gasses and STILL have enough energy left over from hot expanding gasses to provide extra thrust, bleed air, AND drive a generator to provide huge amounts of electricity.
NEVER, EVER, EVER underestimate the power of hot expanding gasses.
Just a few things that run off of expanding hot gasses:
- Guns
- Steam Locomotives
- Nuclear power plants
- Nuclear Submarines and Aircraft carriers
Turbine's can be insanely efficient and powerful. Hot expanding gasses pack a hell of a punch, and driving a turbine is a great way to harness that energy...
So, in conclusion, if you could find a big enough motor with an equally large power supply, you may be able to create boost equivalent of your current turbo set up. You will end up having to do a good amount of fab and in the end would basically have no performance increases.
Hope that helps!
Parthew is offline
post #5 of 5 Old 02-11-2010, 07:23 PM
has anyone seen the ones that run off a secondary engine?????
Ok with all joking aside
i don't think they would be able to make any kind of boost.. the cfm's they would put out i don't think would be a fraction of the Cfm's a turbo sucks in i think it would be an obstruction in the intake track if anything
WTRacing is offline
