Subaru WRX Forum banner
Quick Log Analysis?
2K views 5 replies 2 participants last post by  pzr2874
#1 ·
Hi all,
I'm a noob and just got my Cobb AP and was wondering if anyone would help me by very briefly looking at a few log files I made. I followed the directions on the Cobb website: 3rd gear, 2500 RPM to Redline. I did 2 logs each for stock, Stage 1 normal wg, and Stage 1 high wg. Target boost 15, tapering to 13. I'm at high altitude (~4500 ft), so I think the high wg is appropriate. My car is bone stock, now with an AP. It's a brand new '13 WRX Hatch with ~2000 miles.
My beginner analysis, based on the Cobb site, is the stock and normal wg maps aren't producing enough boost. Stock was an average of ~2 PSI off. DAM was good, stayed at 1. A/F was 0, so good. Feedback knock stayed at 0; however, Fine Knock had some values at the end, but they were decreasing, so OK??
Stage 1 normal wg was very similar to stock, though the boost increased slightly. A/F, DAM and feedback knock were good (0/1/0), but fine knock again showed some values, though decreasing.
Stage 1 high wg was my favorite. Boost was right on target, A/F, DAM and feedback knock all good (0/1/0), but saw some fine knock values again, though less than the other two maps.
Suggestions? And thank you all for your help :D
See less See more
#2 · (Edited)
All looks normal to me..... The altitude is what's holding it back a bit.
Looked at the others as well, why are COBB's maps advancing timing so much? >17* is nuts.
I'd stick with the 2nd HWG log. Can you add vehicle speed as well in the logs?
Looks like there is def some more power to be had.
