quick ap question - Subaru WRX Forum
post #1 of 3 Old 07-16-2013, 05:14 PM Thread Starter
thekamikaze kid's Avatar
quick ap question
once the cobb ap is installed on an 03 wrx, to change maps do i have to put it in test mode again? (meaning connecting the green and white wires again?) or do i just have to connect the odbII port?
thekamikaze kid is offline
post #2 of 3 Old 07-16-2013, 06:05 PM
boo-key's Avatar
For a reflash (which is best) you need to connect the test connectors. You can switch without connecting them though with a realtime flash. I would reflash the map you use most.
realtime:a uploaded calibration for immediate use. The calibration will remain in the ecu until the ecu losses power or is reset
Reflash;Permanent reflash of the calibration onto the ecu.
I would reflash the map you use most often. Are you using off the shelf maps or custom maps? never mix the two! Meaning if you have a custom map reflashed dont do a realtime flash to a off the shelf map.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #3 of 3 Old 07-16-2013, 06:33 PM Thread Starter
cool thanks!
