-   -   quick ap question (http://www.wrxtuners.com/forums/f70/quick-ap-question-36849/)
thekamikaze kid 07-16-2013 05:14 PM
quick ap question
once the cobb ap is installed on an 03 wrx, to change maps do i have to put it in test mode again? (meaning connecting the green and white wires again?) or do i just have to connect the odbII port?
boo-key 07-16-2013 06:05 PM
549 Attachment(s)
For a reflash (which is best) you need to connect the test connectors. You can switch without connecting them though with a realtime flash. I would reflash the map you use most.
realtime:a uploaded calibration for immediate use. The calibration will remain in the ecu until the ecu losses power or is reset
Reflash;Permanent reflash of the calibration onto the ecu.
I would reflash the map you use most often. Are you using off the shelf maps or custom maps? never mix the two! Meaning if you have a custom map reflashed dont do a realtime flash to a off the shelf map.
thekamikaze kid 07-16-2013 06:33 PM
cool thanks! :rocks:
