Question About Stage 1 Map - Subaru WRX Forum
post #1 of 4 Old 07-09-2016, 07:44 AM Thread Starter
nmc_tacticz's Avatar
nmc_tacticz is an unknown
I'm gonna try to make this as short as possible. I have 2009 Wrx with muffler delete, resonator delete and k&n drop in filter. I also use 93 octane.
I have a v2 Cobb accessport and plan on running stage1 map. (I havent set it up yet)
Now,... the Cobb website said its best to return to the stock air filter due to the MAF reading, it should be re-calibrated etc... also, it said I could potentially run the car dangerously lean.
Does anyone have this setup? (or similar) is it really that bad to stay with the k&n drop in filter while running stage1 map? what should I do, any help or advice would great.
Thanks
nmc_tacticz is offline
post #2 of 4 Old 07-10-2016, 02:54 PM
RogueMantis's Avatar
RogueMantis is an unknown
If Cobb says so, I would trust it on their OTS maps. Can't say for your specific year, since I have an 06, but I hear the 08+ are a bit more particular when it comes to intake/exhaust. I would throw a paper filter back in. I assume you have the stock downpipe if you are running stage 1?
06 WRX - Cobb Stage 2
RogueMantis is offline
post #3 of 4 Old 07-10-2016, 07:30 PM
arcticscythe's Avatar
So long story short, the damage has been done already, running with modified intake and exhaust components with no tune is considerably more dangerous then running them with a stage 1 OTS tune.
That said I dont have a scope to put in your cylinder or a used oil analysis to tell how healthy your engine is at the moment but if you run the drop in filter and the stage 1 maps and you take a few logs and everything is cool then I would say no harm no foul.
I had a drop in AEM air filter for about 6 months before I got my Cobb intake and I did not notice any anomalies in my logs when comparing them to cobbs examples and even sending them to Cobb they didnt report anything out of the ordinary.
Thats the best advice I can give, Install the accessport and flash the maps, drive carefully and take logs and if the logs say everything is in spec then your good. If the logs show the ecu freaking out then it might be worth rolling a few parts back to stock.
- Jason
arcticscythe is offline
post #4 of 4 Old 08-31-2016, 07:42 AM
wrxnh's Avatar
wrxnh is an unknown
If anything dump Cobb's OTS map and get e-Tune from Eric at Torqued Performance. My Stage 1 (going Stage 2 this weekend) ran so much better and he can adjust anything (free of charge) over email and send you a new map.
'13 WRX Premium Sedan ISM
wrxnh is offline
