Opensource Read Up.. - Page 2 - Subaru WRX Forum
post #16 of 30 Old 02-12-2008, 07:46 PM
lucky charms's Avatar
lucky charms is an unknown
ok i need help just quik question should i do accessport or just do the tactrix cable and do it my self im not a pro tuner but i do learn fast but any way any advise would be gladly appriated thanx
lucky charms is offline
post #17 of 30 Old 02-13-2008, 06:25 AM Thread Starter
Well both have there good points and bad. I went with it for the simple fact that I can tune my own car and not have to worry about forking over $300-400 every time I change something out. Cobb AP is a wonderful tool and not as technical as the opensource stuff, but again it all depends on what you are going for with your car and how much you want to do on your own.
post #18 of 30 Old 04-16-2008, 10:22 PM
WRXpureSEX is an unknown
Send a message via AIM to WRXpureSEX Send a message via MSN to WRXpureSEX
so when ppl say that u should trust your laptop, does that mean that it has to be runnin for some reason while the car is on? i wouldnt think so but y wouldnt i trust my laptop, b/c i have vista and im not sure what to trust yet... what are other ppl's OS's that already have this?
WRXpureSEX is offline
post #19 of 30 Old 04-17-2008, 12:04 AM
chevarian113's Avatar
chevarian113 is an unknown
Send a message via AIM to chevarian113
Just that you have to be able to trust it's battery power and that it wont freeze up on you. Your laptop will be on to do the reflash, and if it dies in the middle of the flash, you're ####ed.
chevarian113 is offline
post #20 of 30 Old 04-18-2008, 08:25 AM
Like said above,just have your laptop plugged in to your AC adapter and not running off batteries durring the reflashing process.
dumdum is offline
post #21 of 30 Old 04-18-2008, 04:23 PM
ahh makes sense, and yeah its a brand new $2000 laptop so it better not shut down on me....
post #22 of 30 Old 01-03-2010, 07:15 PM
carlos is an unknown
can this be done on a uk wrx bugeye
carlos is offline
post #23 of 30 Old 01-04-2010, 03:13 PM
[post deleted]
Ryan
2009 STi - Cobb Stage 2
VisiX is offline
post #24 of 30 Old 01-05-2010, 09:17 AM
1) don't reply to spam
2) certainly, under any circumstances, don't QUOTE spam.
Just hit the report button and move along
post #25 of 30 Old 05-05-2010, 03:49 PM
Blindzzz is an unknown
Guys,
i want to hit the speed limiter of my WRX, Model 2010. It is not necessary a connector?
Just buy the Tactrix Openport 2.0 and plug it on OBD2 connect to my note by a USB, Save the original map on a safety place. And use the romrider to hit the speed limit.
Its all ok???
Actually i am satisfied with the stock program, in future i must sit down study and see what i really want from the PoisonGod Machine :P.
Thanks for the attention
Blindzzz is offline
post #26 of 30 Old 03-03-2015, 09:30 PM
keithg01 is an unknown
Do the tactrix or cobb tuners allow you to change shift points in a wrx with an auto trans ?
I've been looking at all of the screen shots and see no reference to any transmission shift point adjustments. I have HP Tuners for GM vehicles which has very detailed transmission adjustments for perfomance and standard tunes. This info would be a major selling point
for me, because I hate the way my wifes wrx shifts gears, hunting up and down, sometimes not downshifting soon enough, unless you really lean into the pedal. The car is all untouched stock, and has done this since brand new. The dealer said they all drive like that, and we should consider a stick. I'd love a manual trans in that car but wife wife hates a stick in heavy traffic. Any input about the trans tuning would be greatly appreciated.
EDIT: This poster has an 08 WRX Auto
keithg01 is offline
post #27 of 30 Old 03-04-2015, 08:12 PM
Obviously any 02-08 WRX AUTO has fixed ratios. I don't think the setpoints are adjustable on the 2015. It's a CVT so I guess it's theoretically possible.
The 2015 WRX auto has a very impressive transmission. It has paddle shifters so if you want more RPM you can just click. There are also 8 gears in the gated mode so it's not like you're ever between. I don't think if you owned a 2015 WRX CVT that you'd have any issues with this.
Your stand 3-6 speed auto is fairly slow shifting and uses a torque converter. Because of this the computer doesn't like to downshift because it'll spend more time out of gear than it takes to raise the RPM's by accelerating some. There's usually a "flat out" point on the gas pedal where it will switch and just go into whatever gear gives the most torque at a given speed and people tend to get annoyed at the transition point which seems to be what you're talking about. The 2015 WRX CVT doesn't have transition points like that. It "shifts" faster than you can perceive (faster than an LFA since it's just changing CVT ratios, not really shifting).
post #28 of 30 Old 06-08-2016, 07:17 PM
Devin Buxton is an unknown
i currently have the v3 accesport and want to tune opensource to the soul fact of being able to do it myself anytime I decide to change something up. Will my v3 still show me my numbers while daily driving? or would it be rendered useless once i get into the ecu? I have no gauges and i like to be able to monitor my car at all times when getting into it for the sake of my motor. any info on this would be greatly appreciated.
Devin Buxton is offline
post #29 of 30 Old 06-09-2016, 07:01 AM
titter's Avatar
the cobb AP uses the stock sensors which arent the greatest to begin with.
you will at minimum need a boost gauge and wideband air fuel ratio guage. tuning without these is not recommended.
it wont be rendered completely useless, you can still use it to monitor knock, mpg, and a few other things. you might have to un-marry the AP though. not sure if cobb locks the ecu. might just have to remove the cobb map and revert to stock.
dont forget to wave
titter is offline
post #30 of 30 Old 06-09-2016, 11:01 PM Thread Starter
You should be a able to view your map, unless it is locked by the tuner, with the Cobb tuning software that's free from their site.
