opensource problem - Subaru WRX Forum
post #1 of 19 Old 10-21-2009, 08:41 PM Thread Starter
jed344's Avatar
jed344 is an unknown
opensource problem
ok i have been running cobb accessport v2 for quite a while now and a buddy is buying it from me. So i am going to try opensource. I purchased a xpt stage 2 LC map. The problem is when go to open ROM in ecu flash and find the map and hit to open it, it says ecu flash cannot reconize this ROM image using any current definitions. Now first off the laptop is not connected to the car at the moment does it need to be to even open a map to flash it, and if not i have the newest version of ecu flash. Any ideas as to why it wont read it would be appreciated. thanks
jed344 is offline
post #2 of 19 Old 10-21-2009, 08:50 PM
ratfink's Avatar
ratfink is a helpful contributing member
You need to move the def that came from xpt in the file as the directions say. c, program files, ecuflash, rommetadata, subaru
Brad
ratfink is offline
post #3 of 19 Old 10-21-2009, 08:56 PM
ratfink's Avatar
Also, you need to tell ecuflash what file to get the files from. Once you get it set up, it will work fine.
Brad
ratfink is offline
post #4 of 19 Old 10-21-2009, 08:58 PM Thread Starter
jed344's Avatar
when i did that alot of number xml documents are in there i need to put the files in there? the maps?
jed344 is offline
post #5 of 19 Old 10-21-2009, 09:17 PM
ratfink's Avatar
Yep put the file that looks like the one below in the area below.
\EcuFlash\Metadata\ Subaru\Impreza WRX
XPTxxxxx.XML
Brad
ratfink is offline
post #6 of 19 Old 10-21-2009, 09:21 PM
ratfink's Avatar
My file looks like this:
Brad
ratfink is offline
post #7 of 19 Old 10-21-2009, 11:03 PM Thread Starter
jed344's Avatar
yup i figured it out now thanks just gota set my LC and will load the map tomorow
jed344 is offline
post #8 of 19 Old 10-21-2009, 11:07 PM
ratfink's Avatar
NP, I have been doing this long enough to run into pretty much every problem once. LOL
BTW I am pretty sure you'll find the XPT tune more powerful then the one you ran on the AP.
Brad
ratfink is offline
post #9 of 19 Old 10-21-2009, 11:54 PM Thread Starter
jed344's Avatar
now it wont do it with my rom raider ecu editor or logger says cant find deffinitions omg...
jed344 is offline
post #10 of 19 Old 10-22-2009, 12:09 AM Thread Starter
jed344's Avatar
and yes i did download the deffinitions file's and put them in the rom raider folder so i have no idea this time
jed344 is offline
post #11 of 19 Old 10-22-2009, 11:48 AM
ratfink's Avatar
The defs for romraider are a little different then ecuflash. Under settings you need to tell it where the defs are. You need to load the profile from the XPT package into romraider along with the defs. You don't need to use romraider unless you're going to log. Ecuflash is all you need to flash your ecu. Just make sure to "break in" the map as XPT tells you.
BTW makes sure your using romraider logger and not ecu editor
Brad
ratfink is offline
post #12 of 19 Old 10-22-2009, 12:06 PM Thread Starter
jed344's Avatar
how do i set the lc then on the map ### i see on ecu flash how i can like change it but it doesnt stay checkmarked. sorry bout all the q? im new to opensource
jed344 is offline
post #13 of 19 Old 10-22-2009, 12:13 PM
ratfink's Avatar
what are you calling lc? I'm not remembering that abbreviation.
BTW make sure you user level is set as "developer"
Brad
ratfink is offline
post #14 of 19 Old 10-22-2009, 12:14 PM
ratfink's Avatar
OH, launch control. I got it. LOL
Sadly you would likely need to edit the map in romraider edit for that. Can you email me the map packet from xpt so I can look at it and try to help you?
Brad
ratfink is offline
post #15 of 19 Old 10-22-2009, 12:46 PM
ratfink's Avatar
I need to go for a while. Let me know if you still need help. You can always PM Braden at OSecuroms & XPT Tuning •Index page and he will help you when he's back online.
Brad
ratfink is offline
