i would just uninstall the old version and download the newest one the cable you will get will have the correct drivers in it when you plug it in it will say found new hardware and go through all that
MIKE
TUNED BY 555 MOTORSPORTS
visit me @ www.myspace.com/subienews
I just purchased my cable a couple of days ago and have been reading as much as i can but i have a question, when you speak of the Flash Block do you mean the white connector that is also disconected under the dash or the kick panel? If so you use the other clip that is comming with the tactix cable, right? or do i not need it for the 04 rex ### that would be cool...
Kudos
Life is Short, Speed it up
Hey do you have any info on wastegate adjustment with the xpt stage 2 maps? I flashed mine and im just wondering about adjusting my wastegate to get the right boost for the map/stockturbo
Nice write up. Wish I would have read it before I flashed my Stage 4 limp map in. Had to have some way to get the car to Indiana safely, wasn't about to put my baby on a trailer.
My Tactrix wouldn't connect for anything, then I found the problem. Wasn't hitting ok fast enough. Figured out I could hit ok, THEN put the car in the ON position. Yeah, my car's a freak.
That because they just started flashing the newer CAN bus OBDII cars just this month.......and you never mentioned you had an 08.Fill out your profile.
Aarg matey!
ECU Pirated by RomRaider
i have a 02 wrx and i got my tactriw cable in today but i don't know were to put the block. the only plug i can find that matchs the block is the green test cable and i know that has to be connected. please help asap!
O2 PEARL BLACK WAGON with some modds
