im planning on doing some tuning on my car.... is there a good write up some where to tell me what to look for when logging thing to adjust how much to adjust it ect....
What do you mean it hasn't registered that the file exhists?Are you getting an "error:" or you just can't find the file?
No error. Okay, so you buy the map, download it from the site to your computer, it asks you where to put it, you save it, then save the xml file to the C:\Program Files\OpenECU\EcuFlash\rommetadata\subaru\wrx, then go out to your car, hook everything up (tactrix, green connector (my06) and open ecuflash. When you open ecuflash, then read your ecu, then go to "Open ROM" , there is no ROM to open. So I go and try to manually open it and still , nada. I have had a similar problem every time I buy a map, but after all is said and done , it turns out okay and I really have no idea what has just happened (magic?)
So ,I ended up getting it to work last night around 11:30. I ended up uninstalling ecuflash, sending the zip file over to my other computer and deleting it from my laptop. I then downloaded ecuflash and resent the zip to my laptop, and instead of immediately saving it, I just opened it and extracted the entire zip to my documents and settings folder and then from there was able to save the xml to the program files folder. Flashed the ecu and BAM
stage one is in and not much of a change but u can feel it i like next when i install stage 2 do i remove stage one or just write over it let me know and thanks wrxgtr for the help hope u can keep helping
same thing you did when you flashed stage 1. You read your ecu, then Open Rom and select which map/Rom you want to flash, in this case it will be stage 2, you select that Rom and then write to ecu. Or you can test write to ecu to make sure there are no fatal errors and then write to ecu.
BTW, my car is now very fast
With any outside maps(XPT) you need to also put the definition in the defintions folder for Enginuity.
Aarg matey!
ECU Pirated by RomRaider
ecuflash or enginuity can only read hex(ROM) files they cannot read zipped files so when you do download a zipped file you must unzip it to even see it with these programs
MIKE
TUNED BY 555 MOTORSPORTS
visit me @ www.myspace.com/subienews
Did not need to do this. It atomatically transfers defs through the xml file.
Thanks for your help BTW. Always appreciated, dumdum
I think this was exactly my problem. When I end up finally figuring out what I did to flash the map, I am tired as hell and have been working at it for hours. That combined with my minimal computer skills.
Originally Posted by medic195
thanks for the info mr bithellwgn06 should go stage 2 in a few weeks
you are quite welcome, sir!
Keep us posted and let us know how it goes.
Where exactly is the flash block placed? I have the Tactrix cable. I have a 2004 WRX. Do I still need to connect the green wires together also...in addition to the flash block?
^ Yeah, I flashed Gabe's R29 last Sunday, it's great. It runs better than stock in almost every way . Sounds cliche, but the power curve is 'smooth as butter'.
Thanks for this writeup, it definetly made my first reflash alot easier to (get past the fear to) do.
i have ecu flash but i used it on my evo. i know i have to get another cable but is there a way to switch from evo to sti. i've tried before and it won't switch over.
07 STI
03 subaru WRX <Wifes car
00 2.5 RS
