Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Tuning & Engine Management
Old 05-17-2007, 05:56 PM   #1 (permalink)
wrxgtr's Avatar
Reputation: wrxgtr is more helpful than not
Send a message via Yahoo to wrxgtr
Exclamation OPENSOURCE HOW TO: Flash your ecu useing opensource software
FIRST OF ALL READ PSINUSE'S STICKY to make sure that opensource is what you want and know the issues of doing it wrong
also read these
Rom Raider FAQ - RomRaider - Open Source ECU Tools | Documentation / Rom Raider FAQ
Tuning FAQ - RomRaider - Open Source ECU Tools | Documentation / Tuning FAQ
Scoobypedia | Trusted knowledge for everything Subaru | Knowledge / ECU
How Subaru’s Factory Boost Control System Works - COBB Forums
needed equipment/ tools:
laptop (with full charge)
tactrix cable (for your make and model)
Ecuflash software (Open Source ECU ROMS)
Enginuity software(RomRaider - Open Source ECU Tools | RomRaider / Rom Raider)
[before doing any of the following steps turn your key forward but not on make sure your battery is charged ( if you have a turbo timer shut it OFF)
step 1: connect your tactrix cable to your laptops usb port
step 2: connect your tactrix cable to your diagnostic port
step 3: connect green wires this puts your car in diagnostic mode( you will hear your fans cycle) they are under the dash closest to the drivers door
step 4: open ecuflash
step 5: read your ecu's stock map and save it to a SD card,flash drive, or to your pc
step 6: open your desired map
step 7: test write to ecu to make sure of connectivity or errors
step 8: then if everything is ok write(flash) the desired map to your cars ecu
step 9: read your ecu again and compare your map to the map you flashed(you can use enginuity for this step if desired)
step 10: disconnect the green wires
step 11: start your car and take it for a ride to make sure it runs properly( no sputtering or knock) obvious signs it is not running correctly
step 12: log your car using enginuity
LOG THE FOLLOWING
Air/Fuel Correction #1 (%)
AF Learning #1 (Current)* (%)
Coolant Temperature (F)
Engine Load* (g/rev)
Engine Speed (rpm)
Feedback Knock Correction* (degrees)
Fine Learning Knock Correction* (degrees)
IAM* (multiplier)
Ignition Timing (degrees)
Injector Duty Cycle (%)
Intake Air Temperature (F)
Manifold Rel. Pressure (Corrected) (psi)
Mass Air Flow (g/s)
Throttle Opening Angle (%)
Vehicle Speed (mph)
ENJOY THE NEW POWER AND USE IT SAFELY
MIKE
TUNED BY 555 MOTORSPORTS
visit me @ www.myspace.com/subienews
Old 05-17-2007, 05:59 PM   #2 (permalink)
wrxgtr's Avatar
pre 06 should be the same just add a flash block, i hope everyone likes the write up if anyone has something else to add let me know
MIKE
Old 05-17-2007, 07:35 PM   #3 (permalink)
ArmyWRX's Avatar
Reputation: ArmyWRX is more helpful than not
Send a message via AIM to ArmyWRX Send a message via Yahoo to ArmyWRX
ok i have an 02 rex.... do you have to buy the programs maps ect.... is there a limet to how many time you can reflash
Old 05-17-2007, 08:41 PM   #4 (permalink)
wrxgtr's Avatar
the programs are free(ecuflash,enginuity) you will have to go to www.osecuroms.org and register to find the maps for your car some are free and the xpt maps are not and no i have heard of people flashing their cars hundreds of times before
MIKE
Old 05-17-2007, 09:40 PM   #5 (permalink)
BithellWgn06's Avatar
Timeslip: 9.999 @ 101.92
Club Region: NorCal
Reputation: BithellWgn06 is an unknown
Great job on the writeup. I wish someone had done this before I flashed.
The green connector was a hard one for me. I had no idea where it was.
BJJ for the win!
Old 05-17-2007, 09:55 PM   #6 (permalink)
wrxgtr's Avatar
glad i couldnt help lol
MIKE
Old 05-17-2007, 10:01 PM   #7 (permalink)
Reputation: oh2wrx is an unknown
where can i buy a tactrix cable? im thinking of buying that instead of the cobb AP2.
Old 05-17-2007, 10:05 PM   #8 (permalink)
wrxgtr's Avatar
psinuses sticky opensource read up will provide you with that info
MIKE
Old 05-18-2007, 07:42 AM   #9 (permalink)
Reputation: dremers is an unknown
awesome write up.
i think it would be good to post comparisons of stage 1 and stage 2 using enginuity even through stage 4. just so newbees could see the differences. even i want to see the difference between stage1 and stage 4.
Old 05-18-2007, 07:17 PM   #10 (permalink)
wrxgtr's Avatar
should i put like a disclaimer on this HOW TO ? instead of reffering to psinuse's thread
MIKE
Old 05-18-2007, 07:23 PM   #11 (permalink)
Club Region: NorCal
Originally Posted by dremers View Post
awesome write up.
Where is there a stage 4?
BJJ for the win!
Old 05-21-2007, 08:46 AM   #12 (permalink)
FlimFlamMan's Avatar
Reputation: FlimFlamMan is an unknown
Nice write up! Excellent directions and pics.
I've noticed some folks say it may take a few extra cranks to get your WRX started after flashing a new map but that was not the case for me. It started up normally. However, when I first got the Tactrix cable I saved my stock ROM to disk (no writing to the ECU) and it did take a few extra seconds for it to start up after that.
Old 05-23-2007, 09:24 PM   #13 (permalink)
Reputation: medic195 is an unknown
nice write up great job much help
Old 05-23-2007, 09:24 PM   #14 (permalink)
are xpt stages better
Old 05-23-2007, 09:39 PM   #15 (permalink)
Club Region: NorCal
Okay, I CAN use some help with this flash. I have the stage 3 race map. ( I have also flashed stage 2 and stage 3 successfully in the recent past) I saved my xml file to the C:ProgramFiles..... and when I open ecuflash, it has not registered that that file exists. I have restarted my computer, tried to open file before and after reading my ecu, stood on my head and on one foot. Help me out someone. Has anyone had this problem?
Thanks,
Dean
BJJ for the win!
