Noticed some oil in intake hose before inter cooler - Subaru WRX Forum
 2Likes
  • 2 Post By BLAZE2099
post #1 of 6 Old 09-29-2013, 08:49 PM Thread Starter
DS07Turbowagon's Avatar
Got an 07 WRX as I was changing out my clutch I took my inter cooler off and found SOME oil inside the intake hose from engine to intercooler. It wasn't much just coated the bottom of the hose about 1.5 inch wide section. Any ideas if there's is an issue here?
Sent from AutoGuide.com App
DS07Turbowagon is offline
post #2 of 6 Old 09-29-2013, 09:07 PM
Probably just blow bye...you'll always have a little. But, if it's pooling up or a lot i'd be worried. A little isn't much to worry about.
post #3 of 6 Old 09-29-2013, 09:47 PM
It's normal I'm pretty sure, Most cars have PCV valves that rerout back to the intake, that's why people buy valve cover breathers or catch cans, the oil definately reduces efficiency of the intercooler. Now if there's a lot you might have worn rings or valve seals. But some is normal
n8mcd is offline
post #4 of 6 Old 09-30-2013, 12:18 AM Thread Starter
Thanks it's definitely not pooled nor was it dripping out of the hose it was just wet.
post #5 of 6 Old 09-30-2013, 04:18 AM
That's normal, you can stop panicking.
turmic and Haw1es like this.
post #6 of 6 Old 09-30-2013, 08:51 AM
Or AOS systems to try and reduce the blow bye a tad.
